Message 11 of 28
Re: Slow download, questions about BT Wholesale speed tester.
Can you remove the faceplate from the master socket, connect a phone with a filter and dial 17070 to carry ou the quiet line test please.
If there's no noise, please connect the router to the filter in the test socket, run the above test again and post up the hub stats from the test socket.
Message 12 of 28
Thanks Webby,
No noise on quiet line, now also getting DNS errors on web pages, here is the hub data plugged into socket.
Product name:
BT Hub 6A
Serial number:
+084316+NQ64777791
Firmware version:
SG4B10002244
Firmware updated:
30-Jan-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 0 Hours 5 Minutes 6 Seconds
Data rate:
20.00 kbps / 62.61 kbps
Maximum data rate:
20000 / 74383
Noise margin:
0 / 6.5
Line attenuation:
18.3
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
2 MB Uploaded / 80 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
Virginmedia
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
Virginmedia_N-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:6B:DA:2B
Software variant:
Boot loader:
7.33.1
Message 13 of 28
Heres the latest result of the BT Wholesale diagnostics pages
Message 14 of 28
Should I pack this in and just wait for the engineer next week?
Message 15 of 28
The BT Wholesale check keeps flipping from max potential speeds of around 60mbs (see above) and 31mbs as below.
Message 16 of 28
You have a fault somewhere causing your sync speed to vary wildly. Is it still in the test socket?
Message 17 of 28
No Webby, I replaced the front plate and re-ran th tests and there was no apparent difference. Here are the current hub stats, is the noise margin relevant here?
Product name:
BT Hub 6A
Serial number:
+084316+NQ64777791
Firmware version:
SG4B10002244
Firmware updated:
30-Jan-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 0 Hours 55 Minutes 8 Seconds
Data rate:
20.00 kbps / 32.80 kbps
Maximum data rate:
27001 / 38130
Noise margin:
10.9 / 18.3
Line attenuation:
18.3
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
106 MB Uploaded / 476 MB Downloaded
Broadband username:
BT Wi-fi:
Not active
Virginmedia
Smart (Channel 11)
Virginmedia_N-5
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:6B:DA:2B
Software variant:
Boot loader:
7.33.1
Message 18 of 28
The event log, since I rebooted the hub this morning about an hour ago is nearly 142 PAGES of events like this;
R_LAN:LAN Neighbor Discovery : Host 2a00:23c4:519d:c500:f84e:3f30:95dc:b514 is set active
07:44:05, 09 Mar.
BR_LAN:LAN Neighbor Discovery : Host fe80::a677:33ff:fec2:54d6 is set active
07:43:59, 09 Mar.
BR_LAN:LAN Neighbor Discovery : Host fe80::92e7:c4ff:fec8:c86 is set active
07:43:57, 09 Mar.
BR_LAN:LAN Neighbor Discovery : Host 2a00:23c4:519d:c500:9cb6:b7cf:a861:8f0b is set active
07:43:56, 09 Mar.
BR_LAN:LAN Neighbor Discovery : Host 2a00:23c4:519d:c500:9cb6:b7cf:a861:8f0b is set inactive
07:43:54, 09 Mar.
BR_LAN:LAN Neighbor Discovery : Host 2a00:23c4:519d:c500:3d10:4d63:646d:130e is set active
Message 19 of 28
Is there any mileage in setting the HH6 to modem mode and seeing what happens?
I have an engineers visit arranged for next Monday, is there any way that I can get an earlier visit....my famly are giving me real grief now Smiley Sad
Message 20 of 28
You really need to connect to the test socket and leave it there for a week, to see if the connection varies. If it does, the problem is external. If it doesn't the issue is your home wiring.
When you last connected to the test socket, the connection rate almost doubled.
