cast4x
Message 1 of 2
Slow download speed after disconnects
On the 21st/22nd January, my router would keep dropping its connection.  It would flash orange, go blue for about 30 seconds and then flash orange again.  It stayed connected on the afternoon of the 22nd but downloads were really slow, and then started disconnecting again all afternoon/evening of the 27th.
Since then, the connection has been fine as far as I know but my download speed is really slow, around 200Kbps when I used to get around 2 megabytes a second.
I have a BT Home Hub 5.  I wasn't sure about the dsl rates but found this in the log:
Down Rate=2271Kbps, Up Rate=1072Kbps; SNR Margin Down= 21.3dB, Up=7.8dB
The speed test had the following results:
Download speed achieved during the test was - 1.96Mbps
For your connection, the acceptable range of speeds is 0.8 Mbps-2Mbps
IP profile for your line is - 2Mbps
Upload speed achieved during the test was - 0.88Mbps
Upstream Rate IP profile on your line is - 0.83Mbps
From reading around, I'm guessing this has something to do with DLM restricting the downloads due to the constant disconnects and that, in a few more days, I should hopefully see some improvement.  Can anyone confirm this or help?
1 REPLY 1
imjolly
Message 2 of 2
Re: Slow download speed after disconnects
you are correct in the you are now in a banded profile due to all the disconnections and if you can now maintain a stable connection then the banding will start to release with noise margin reducing and speed increasing
https://www.plus.net/help/archive/broadband/broadband-terminology-guide/?supportarchive
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone  any noise is a probalem for your broadband and you would need to report a phone fault to 151
