Paulie
Message 1 of 4
Slow download speed
My download speed has been consistently low over the last few months.
I've tried nearly everything suggested in this forum and on BT's help pages
Would increasing my IP profile increase my download speed, if so, who do I need to contact to get this done?
Speedtest results and line details below.
 Download speed achieved during the test was - 2 Mbps For your connection, the acceptable range of speeds  is 400 Kbps-2 Mbps. Additional Information: Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 2 Mbps
ADSL line status
Connection Information
Line stateConnected
Connection time2 days, 15:18:02
Downstream8,128 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeFast
Noise margin (Down/Up)8.6 dB / 28.0 dB
Line attenuation (Down/Up)13.0 dB / 6.0 dB
Output power (Down/Up)12.4 dBm / 1.9 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)26 / 0
HEC Errors (Down/Up)23 / 0
Error Seconds (Local/Remote)26 / 0
3 REPLIES 3
Message 2 of 4
Re: Slow download speed
Hi you can try live help at this link and as them to reset your IP profile    Live help
ajfelov
Message 3 of 4
here is slowly bb Smiley Very Happy
Line state:Connected
Connection time:2 days, 15:31:42
Downstream:192 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):9.3 dB / 11.0 dB
Line attenuation (Down/Up):63.5 dB / 31.5 dB
Output power (Down/Up):11.3 dBm / 12.4 dBm
FEC Events (Down/Up):5077 / 6
CRC Events (Down/Up):357 / 5
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):164 / 8
Error Seconds (Local/Remote):0 / 0
Message 4 of 4
ajfelov
Could you please start your own new post please to save any confusion with replies
