gregm
Message 11 of 15
Re: Slow download speeds from github.com
Things are starting to get back to normal now.
1033109 bytes downloaded from github.com at 5.08 Mbps
milhousevh
Message 12 of 15
Yes, download speeds are starting to get back to where they should be - thank God for that...! 🙂
mrproper
Message 13 of 15
Hmm, scratch that, still slow here:
1033109 bytes downloaded from github.com at 0.27 Mbps
Seems to be fine early in the morning, and very slow at peak evening time for me (same yesterday).
Edit: And using this, I get 50 Mbps: http://speedtest.btwholesale.com/ , so it's just GitHub.
Webby
Message 14 of 15
What's to say the problem isn't with Github
mrproper
Message 15 of 15
Webby - Quite right, though I wasn't having issues on my work connection, which suggests the ISP I have at home is a good place to start.
However, happy to report I now see it working well at peak evening time too - so whatever / whoever the issue, I'm now a happy man 🙂
3.1.3-Krypton-Beta3.tar.gz        100%[==========================================================>]  10.65M  36.7Mb/s    in 2.4s
