Truffle1234
Message 1 of 11
Slow download speeds
I have BT Infinity 2 with Home Hub 4 - Type A and we are 0.7 miles from the exchange. I am only getting download speeds of 14 Mbs. The BT Broadband Availability Checker says for the exchange says VDSL Range A High 35 Low 27.4, VDSL range B High 26.6 Low 14.
Other reports in our area show people getting download speeds of 43 from BT Infinity . Should we only be getting 14 ?
10 REPLIES 10
Message 2 of 11
Re: Slow download speeds
What modem do you have?
Webby
Message 3 of 11
Wired or wireless connection?
Truffle1234
Message 4 of 11
Its a BT Openreach Modem
Truffle1234
Message 5 of 11
It is 15Mbs on wired connection and 14.7 on wireless
imjolly
Message 6 of 11
are you suing the test socket with a new filter to eliminate problems with internal wiring
Truffle1234
Message 7 of 11
It is one of those double sockets so I thought it doesn't need a filter, but perhaps I should try that ?
imjolly
Message 8 of 11
it doesn't need a separate filter but you can try test socket with a filter  test scket shown by black arrow
Truffle1234
Message 9 of 11
I am not sure what kind of modem it is . It says ECI Telecom Ltd Item Code 061513 on the back
Truffle1234
Message 10 of 11
Thanks imjolly I will try that But how do j get a filter ? From BT ?
