Message 11 of 34
Re: Slow evening speeds Infinity 1
The sync speed your router reports is an entirely different thing to download speed. Sync speed is the speed of the physical link between your router and the DSLAM in the green cabinet. Download speed is the speed of the network to whichever server/speedtest site you are connected to.
Message 12 of 34
Thanks you so much for this. That would explain a lot. Unfortunately BT also cannot see an issue on there end. Has anyone else reporting the issue recently also been told there's no issue on the line?
Message 13 of 34
Ok so 7:50am and still getting slow speeds...
Router still shows sync'd at the full 55000 down and 9999 up.
IP profile on BT test shows 53.18Mbps but clearly not achieving.
Message 14 of 34
Seems to be sporadic at this time of morning, just re-run and got my full 52/9Mb there enough.
Moderator
Moderator
Message 15 of 34
Hi @Sparx,
What exchange are you connected? I'll can to see if there are any know issues reported for that exchange.
PaddyB
Message 16 of 34
Hi Paddy
I'm on the Scartho exchange (SLSC).
Moderator
Moderator
Message 17 of 34
Hi @Sparx,
Thank you for replying. I had a look but can't see any known issues for that exchange.
I understand that you have reported a fault through to BT and are due a call back tomorrow. Let me know how you get on with that call tomorrow and if needed, I'll be able to take a look at what is happening with your fault.
PaddyB
Message 18 of 34
Lunch time results, as it should be...
Message 19 of 34
Absolute joke, come the evening and back to 3Mb speeds.
IP profile still clearly shows I should be achieving approx 53Mb.
YouTube videos constantly buffer, all it's good for is browsing if I'm lucky. Web pages timing out again.
Message 20 of 34
@Keith_Beddoe sorry, what do you mean? What's moved where?
