Keith_Beddoe
Message 11 of 23
Re: Slow line speed since 13 December
It looks like BT Infinity is available on your cabinet, so if its more speed you need, then that might be worth considering.
ageingmuso
Message 12 of 23
Just looked and infinity wiould cost less than I am paying at the moment, so I think I wll go for the upgrade.
ageingmuso
Message 13 of 23
Still does not explain why the speeds droped so much on the existing connection a smentioned perviously it was always 6.8 Mps, so just wondering what might cause this.
Is it simply a marketing ploy to get me on to infinity?
Webby
Message 14 of 23
Absolutely not. It'll likely be an external fault, or an issue with the home wiring.
Have you tried connecting to the test socket?
ageingmuso
Message 15 of 23
According to the bt fault check it says fault is at the Bt retail server.
ageingmuso
Message 16 of 23
BTW its also said I would be contacted but I have had no responce from BT directly about it?
ageingmuso
Message 17 of 23
So I keep reading about waiting 10 days for speed to get back to normal, current WAN up time 96:23:50. do I simply wait till it hits 240:00:00 and hope that something improves?
ageingmuso
Message 18 of 23
Anyone care to comment on this?
http://downdetector.co.uk/problems/bt-british-telecom/map
There seem to be a lot of people experiencing problems at present.
Anyway happy new year.
ageingmuso
Message 19 of 23
I have spotted one thing, the line seems to drop once, either in the middle of the night or very early in the morning. It would be nice if this was the DLM sorting it self out but I won't hold my breath.
For anyone that wants a bit of info on the tech side this link is very usefull. http://www.kitz.co.uk/adsl/
DavidM
Moderator
Moderator
Message 20 of 23
Hi @ageingmuso,
Thanks for posting. I'll be happy to take a closer look at this for you if you wish. Can you please drop me over an email with your details? You'll get the contact he moderators link in my profile.
Cheers
David
