Derpingtons
Message 1 of 18
Slow net on evenings
I should be getting around 6mbps download but every day between about 5pm and 10pm its down to 1.88 mbps. It has been like this for the past few weeks now. Is this going to be fixed soon or am i going to find a new ISP? I've been on BT for a few years and not had one single problem.
http://www.speedtest.net/result/1756308217.png
17 REPLIES 17
imjolly
Message 2 of 18
Re: Slow net on evenings
welcome to the forum
this is a community forum where customers help customers and only BT employees are the mods
in order for the forum members to help please can you post the adsl stats from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester (MAC users may have problems) http://speedtester.bt.com or http://bt.custhelp.com/app/answers/detail/a_id/9354/c/346,4740,5520 and post the results .
are you connected directly to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
arron1718
Message 3 of 18
a few others have had the same issue
so far bt dont know what the problem is
Derpingtons
Message 4 of 18
Connection information
Line stateConnected
Connection time0 days, 8:04:23
Downstream5,504 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)12.0 dB / 15.0 dB
Line attenuation (Down/Up)46.0 dB / 25.0 dB
Output power (Down/Up)19.8 dBm / 12.3 dBm
Loss of Framing (Local)14
Loss of Signal (Local)2
Loss of Power (Local)0
FEC Errors (Down/Up)125956 / 11
CRC Errors (Down/Up)23 / N/A
HEC Errors (Down/Up)N/A / 6
Error Seconds (Local)4390
BT speed tester gave a result of 1.77 mbps download speed.
imjolly
Message 5 of 18
sorry but need the normal btspeedtester result and not the beta figure as it gives your profile and download speed
your connection time is only 8Hrs is that due to a manual reset or the router dropping connection?
what about where you are connected - master or test?
quiet line test?
john46
Message 6 of 18
arron 1718 the problem is normally peak time exchange congestion if speed drops between 4pm and midnight but hub stats and speed tests over at least 24 hours so please do not say BT do not know what it is
Derpingtons
Message 7 of 18
I thihnk the speeds have picked up again now, I'll redo it tomorrow aswell.
Results Image not loaded
Test1 comprises of Best Effort Test:  -provides background information.
 Download  Speed
 3799 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 3799 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :5504 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 4500 Kbps
I heard some people on virgin also had slow speeds because of exchange congestion but theirs seems to be fine now. If that is the problem is there nothing i can do about that?
imjolly
Message 8 of 18
the btspeedtester results look ok. another set tomorrow at say about 6/7pm or when you think download speed slow would help.  at present it does not look like congestion
Derpingtons
Message 9 of 18
So my internet should be fine judging by the results of btspeedtester? I'm still getting 150+ ping to game servers.
imjolly
Message 10 of 18
yes the results from btspeedtester look just as you would expect for profile and download speed
