john46
Message 11 of 18
Re: Slow net on evenings
I agree with imjolly not a congestion problem post another test tomorrow your ping may be a routing problem if the next test is ok then you will need the mods help to look at any possible routing issues
Derpingtons
Message 12 of 18
But why the huge speed drop within these hours? Would that also happen with a routing problem? Its been like this for about 3 weeks everyday. It works fine all day then at 5pm its just drops. 3mbsp is not fine.
imjolly
Message 13 of 18
your profile of 4500 is correct for your connection speed and your download speed is ok for your profile especially at the time during peak hours.  as I said if it starts to run slow then do btspeedtester and post the results
Derpingtons
Message 14 of 18
Okay could you tell me what IP Profile actually is? and what is "Your DSL Connection Rate" What does that mean?
As far as i know I've never had lower speeds than 5mbps. I'm on BT total broadband right now if i move to BT infinity will my IP profile increase?
imjolly
Message 15 of 18
this is better explained by some reading  http://www.kitz.co.uk/adsl/IPprofile.htm
http://www.kitz.co.uk/adsl/max_speed_calc.php
john46
Message 16 of 18
yes your ip profile will increase when on infinity
john46
Message 17 of 18
your dsl connection rate is the speed your hub connects to the exchange equipment at
Derpingtons
Message 18 of 18
Well thanks anyway.
