Message 1 of 13
Slow rural broadband question
Hi,
I am one of the many who (has almost resigned himself to not ever getting a decent connection)live in rura areas. I have been having speed drops for a while now, one thing I have noticed after an IP lookup is that I appear to have moved from my present location north of civilisation to the middle of wales? Would this have an affect on my speed drop. Currently my speed hovers around 1mb last year it was around 1.9mb. I have been onto BT several times and they have "reset my connection" but to no avail. Any ideas?
chipeater
Tags (4)
12 REPLIES 12
Message 2 of 13
Re: Slow rural broadband question
the location will not affect your conenction speed
can you post the adsl stats from your router please and results from btspeedtester diagnostic test
Message 3 of 13
Will do when i get home from work
Message 4 of 13
Hi here are the various results from hub and speedtest
1. Product name:
BT Home Hub
2. Serial number:
+068543+NQ43939362
3. Firmware version:
Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 04/07/15
4. Board version:
BT Hub 5A
5. DSL uptime:
11 days, 23:25:02
6. Data rate:
448 / 1600
7. Maximum data rate:
1000 / 1728
8. Noise margin:
20.0 / 16.5
9. Line attenuation:
31.0 / 57.4
10. Signal attenuation:
31.0 / 54.4
11. Data sent/received:
2.8 GB / 45.7 GB
12. Broadband username:
bthomehub@btbroadband.com
13. BT Wi-fi:
14. 2.4 GHz Wireless network/SSID:
hoobyjoobi
15. 2.4 GHz Wireless connections:
Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:
WPA2
17. 2.4 GHz Wireless channel:
Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:
hoobyjoobi
19. 5 GHz Wireless connections:
Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:
WPA2
21. 5 GHz Wireless channel:
22. Firewall:
Default
23. MAC Address:
c8:91:f9:89:32:62
24. VPI/VCI:
0 / 38
25. Modulation:
G.992.1 Annex A
26. Latency type:
Interleaved
27. Software variant:
AA
28. Boot loader:
1.0.0
Message 5 of 13
problem is your very high noise margin - normal is about 6db   as you have a great stbale connection and DLM has not dropped the noise margin then we can get mod help to reset noise margin  this will give you better down speed and therefore better download speed
mods will post a contact us link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
Message 6 of 13
Thanks will wait for Mods
Community Manager
Community Manager
Message 7 of 13
Hi Chipeater,
Welcome to the forum and thanks for posting.  Really sorry to hear of the problems you are having.
I would have to agree with Imjolly, it is most certainly your high noise margin which is pushing your speeds down, 20dB is very high and I am surprised that your connection has been up for 11 days.  I would have expected your noise margin to come down significantly as your connection appears to be stable.
Your noise margin tells you that there is/was interference coming from somewhere that has affected your connection. usually noise interference will result in your connection becoming very unstable which usually manifests by your connection dropping, the noise margin increases in an attempt to stabilise the connection.  In theory your noise margin should come down when the source of the interference stops however this can get stuck at times.
This is something that I can help with.  I can reset the noise margin back to the target value of 6dB.  This will have an immediate affect on your speed.  This will also be a good way to check if the cause of the interference has now gone.  Either way we will get to the bottom of this.
Click on my username (SeanD) and under the 'About me' section of my profile you will find a the 'Mods contact link'.
Cheers
Sean
Message 8 of 13
Still waiting for a response from Mods after contacting them on Sunday and Tuesday - meanwhile everyone in the house has time shares on internet maximum time allowed each go 15 mins 😉
Message 9 of 13
The mods take 3/5 working days to reply personally to you after you send in the contact us form the waiting time excludes weekends and bank holidays.
you do not need to  make additional requests for mod help after you have have received the tracking reference after sending the contact form
Message 10 of 13
as I said in my previouis post - it can take 3/5 working days for mods to get back to you   you are in a queue of other customers waiting for mod help all of whom consider their problem a priority hence why mods reply in order the emails are received.  you just need to wait until your email reaches top of inbox
