Message 21 of 45
Re: Slow slow slow
I will keep an eye on it over the next few days and report back, thanks a lot for all your help and patience.
Message 22 of 45
Re: Slow slow slow
Okay folks back again, this is getting worse, over the weekend the internet was really slow and dropped connection on several occasions, just run a speed test and im getting a wopping 1.8mbps download speed, brilliant, emailed BT last week regarding this and still waiting on someone a real person to get back to me, this is really bad customer service.
Message 23 of 45
Re: Slow slow slow
Make a direct connection from your PC to the modem which will eliminate the homehub. Follow this guide to do that. Use your computer as normal and re-run your speed test. If it improves  you will know it is possibly a faulty hub. If possible keep it connected without the homehub for a day or so just to be sure. You will obviously not be able to use wireless when connected like this.
Step 1: Remove the homehub from the modem
Step2: Connect your pc/laptop into the modem using LAN1 port
Step3: Open network and sharing centre on windows and click set up a new connection or network
Step4: Connect to the internet then click make a new connection Broadband PPPoE
Step5: Username bthomehub@btbroadband.com and the password as BT
Step6: connect, If it doesn't,keep pressing try again until it does.
Message 24 of 45
Re: Slow slow slow
Cheers gg30340 i will give this a go tomorrow and report back.
Message 25 of 45
Re: Slow slow slow
gg30340 i done as you instructed and im on line done a speed test and its reading 37.85mbps i will run it again every hour until i go to bed and again in the morning and report back. cheers
Message 26 of 45
Re: Slow slow slow
When i finish running the tests do i just connect the BT home hub,??
Message 27 of 45
Re: Slow slow slow
Message 28 of 45
Re: Slow slow slow
I ran a speed test at the following times, and git good results using the wired connection, i will remove it now and plug the Home hub back in and monitor it over the next twenty four hours. how would i know if the firmware on the hub needed updated?
6pm -  35.86
7pm  - 35.43
8pm - 37.63
9pm  - 36.88
10pm  - 37.42
11pm -  35.82
12pm - 34.82
7am -  37.88
8am - 37.45
9pm - 37.44
10pm 37.34
11am - 37.88
12am - 36.98
1pm - 37.57
2pm - 37.45
3pm - 37.25
4pm - 37.33
5pm - 37.57
Message 29 of 45
Re: Slow slow slow
Message 30 of 45
Re: Slow slow slow
Home hub back on ran a quick test 3.98      Software version V100R001C01B036SP05_L_B | Time & date 17:32 10/09/2014
