Message 31 of 45
Re: Slow slow slow
Your firmware is obviously up to date. One last thing to check just to rule it out. Do you have another Ethernet cable you could use to connect the hub and modem. I suspect you will have used the same one when you made the direct connection but it is just to make sure there is not a problem with one of the end connectors being loose.
Message 32 of 45
Re: Slow slow slow
I will try another cable,
Message 33 of 45
Re: Slow slow slow
Tried another cable, it works just as good as the other cable, but when ypu go back to wireless the speed just now is 0.86mbps, this is getting really really frustrating, does no one from BT look at these post. how do i go about raisning this issue with BT
Message 34 of 45
Re: Slow slow slow
This is a BT residential customer to customer forum. Your post does not go to BT. The only BT staff are the forum moderators who do not necessarily read all the posts.
It would appear that you have a faulty Homehub. You need to contact BT  0800 111 4567 and report a fault. Inform them what you have done to establish that the Homehub is faulty but they will no doubt want to go through their own check list. They will eventually get to the bit that tells them to replace the hub. As long as you are still in contract a replacement should be free.
Message 35 of 45
Re: Slow slow slow
Thanks buddy for all you help and patience once again, i emailed BT still waiting on a responce, i am out of contract, if i was to get a HH 5 would i just need to plug it into the white modem and away i go?
Distinguished Guru
Message 36 of 45
Re: Slow slow slow
You don't need a modem with the HH5, just plug it into the master socket.
If not, I'll try again 🙂
Message 37 of 45
Re: Slow slow slow
So do i just plug in the HH 5 into the master socket and away i go, oh after i put in my user name and password?
Message 38 of 45
Re: Slow slow slow
you just plug in the HH5 no username and password are needed as the are preset in the hub
Distinguished Guru
Message 39 of 45
Re: Slow slow slow
If you're on BT Infinity, the HH5 just plugs in and away you go. No need for a username and password.
Message 40 of 45
Re: Slow slow slow
You will need to re-contract and make it part of the deal that you get a HH5. You could always buy your own router for anything from £20 upwards and use that with the Openreach modem or buy a VDSL modem/router if you don't want to use the Openreach modem rather than re-contracting.
EDIT: You would be better calling them than using email. If you want to recontract call the Options Team 0800.800.030 and hold out for the HH5 if that is what you want.
