tehrules
Message 1 of 19
Slow speed and authentication issues
Been having serious speed issues as of late.
My line is syncronising at 4mbps however I'm bearly getting 3mbps download on speed tests.
I am also getting issues with authentication and being kicked off the BT network, with the modem failing to authenticate.
Please note; I am not using the BT Homehub. I refuse to use it on privacy grounds, and on the fact it has a habbit of constantly rebooting at random times of the day.
18 REPLIES 18
Message 2 of 19
Re: Slow speed and authentication issues
if you have a 4mb connection speed then 3mb download is about right - post you adsl stats and btspeeedtester results please
tehrules
Message 3 of 19
Jan 2 13:09:09ppp: [wan_link0] LCP: Down event
Jan 2 13:09:09ppp: [wan_link0] Link: reconnection attempt 66 in 2 seconds
Jan 2 13:09:11ppp: [wan_link0] Link: reconnection attempt 66
Jan 2 13:09:11ppp: [wan_link0] PPPoE: Connecting to ''
Jan 2 13:09:20ppp: [wan_link0] PPPoE connection timeout after 9 seconds
Jan 2 13:09:20ppp: [wan_link0] Link: DOWN event
Jan 2 13:09:20ppp: [wan_link0] LCP: Down event
Jan 2 13:09:20ppp: [wan_link0] Link: reconnection attempt 67 in 3 seconds
Jan 2 13:09:23ppp: [wan_link0] Link: reconnection attempt 67
Jan 2 13:09:23ppp: [wan_link0] PPPoE: Connecting to ''
Jan 2 13:09:32ppp: [wan_link0] PPPoE connection timeout after 9 seconds
Jan 2 13:09:32ppp: [wan_link0] Link: DOWN event
Jan 2 13:09:32ppp: [wan_link0] LCP: Down event
Jan 2 13:09:32ppp: [wan_link0] Link: reconnection attempt 68 in 1 seconds
Jan 2 13:09:33ppp: [wan_link0] Link: reconnection attempt 68
Jan 2 13:09:33ppp: [wan_link0] PPPoE: Connecting to ''
Jan 2 13:09:42ppp: [wan_link0] PPPoE connection timeout after 9 seconds
Jan 2 13:09:42ppp: [wan_link0] Link: DOWN event
Jan 2 13:09:42ppp: [wan_link0] LCP: Down event
Jan 2 13:09:42ppp: [wan_link0] Link: reconnection attempt 69 in 3 seconds
Jan 2 13:09:45ppp: [wan_link0] Link: reconnection attempt 69
Jan 2 13:09:45ppp: [wan_link0] PPPoE: Connecting to ''
Jan 2 13:09:54ppp: [wan_link0] PPPoE connection timeout after 9 seconds
Jan 2 13:09:54ppp: [wan_link0] Link: DOWN event
Jan 2 13:09:54ppp: [wan_link0] LCP: Down event
Jan 2 13:09:54ppp: [wan_link0] Link: reconnection attempt 70 in 3 seconds
Jan 2 13:09:57ppp: [wan_link0] Link: reconnection attempt 70
Jan 2 13:09:57ppp: [wan_link0] PPPoE: Connecting to ''
Jan 2 13:10:06ppp: [wan_link0] PPPoE connection timeout after 9 seconds
Jan 2 13:10:06ppp: [wan_link0] Link: DOWN event
Jan 2 13:10:06ppp: [wan_link0] LCP: Down event
Jan 2 13:10:06ppp: [wan_link0] Link: reconnection attempt 71 in 2 seconds
Jan 2 13:10:08ppp: [wan_link0] Link: reconnection attempt 71
Jan 2 13:10:08ppp: [wan_link0] PPPoE: Connecting to ''
Jan 2 13:10:17ppp: [wan_link0] PPPoE connection timeout after 9 seconds
Jan 2 13:10:17ppp: [wan_link0] Link: DOWN event
Jan 2 13:10:17ppp: [wan_link0] LCP: Down event
Jan 2 13:10:17ppp: [wan_link0] Link: reconnection attempt 72 in 4 seconds
Jan 2 13:10:21ppp: [wan_link0] Link: reconnection attempt 72
Jan 2 13:10:21ppp: [wan_link0] PPPoE: Connecting to ''
Jan 2 13:10:30ppp: [wan_link0] PPPoE connection timeout after 9 seconds
Jan 2 13:10:30ppp: [wan_link0] Link: DOWN event
Jan 2 13:10:30ppp: [wan_link0] LCP: Down event
Jan 2 13:10:30ppp: [wan_link0] Link: reconnection attempt 73 in 3 seconds
Jan 2 13:10:33ppp: [wan_link0] Link: reconnection attempt 73
Jan 2 13:10:33ppp: [wan_link0] PPPoE: Connecting to ''
Jan 2 13:10:42ppp: [wan_link0] PPPoE connection timeout after 9 seconds
Jan 2 13:10:42ppp: [wan_link0] Link: DOWN event
Jan 2 13:10:42ppp: [wan_link0] LCP: Down event
Jan 2 13:10:42ppp: [wan_link0] Link: reconnection attempt 74 in 2 seconds
Message 4 of 19
your router should be set to pppoA not pppoE
tehrules
Message 5 of 19
I would if the modem is doing the authentication. My firewall does the authenticating, the modem is in bridge mode.
PC --> Firewall ---> Modem ---> Phone line ---> Exchange ---> Internet
Message 6 of 19
pppoE is used on cable or fibre and pppoA is for adsl
Message 7 of 19
unless you are on Infinity you you need to set your router to ppp0A
tehrules
Message 8 of 19
The modem is in bridge mode so no, its got to use PPPoE.
It works, and has worked for weeks, but recently the connection drops and fails to reauthenticate.
tehrules
Message 9 of 19
Here's the proof PPPoE is working as my line has just come back up again.
Just so you are aware, PPPoA is PPPoE done via an ADSL router from what I have read. So with the modem in bridge mode like my setup using PPPoE effectively once it hits the modem it is "converted" to PPPoA as it goes down the ADSL line.
Jan 2 13:26:42ppp: [wan_link0] LCP: LayerUp
Jan 2 13:26:42ppp: [wan_link0] CHAP: rec'd CHALLENGE #1 len: 35
Jan 2 13:26:42ppp: [wan_link0] Name: "bras-red3.gi-b"
Jan 2 13:26:42ppp: [wan_link0] CHAP: Using authname "bthomehub@btbroadband.com"
Jan 2 13:26:42ppp: [wan_link0] CHAP: sending RESPONSE #1 len: 46
Jan 2 13:26:42ppp: [wan_link0] CHAP: rec'd SUCCESS #1 len: 42
Jan 2 13:26:42ppp: [wan_link0] MESG: CHAP authentication success, unit 3989
Jan 2 13:26:42ppp: [wan_link0] LCP: authorization successful
Jan 2 13:26:42ppp: [wan_link0] Link: Matched action 'bundle "wan" ""'
Jan 2 13:26:42ppp: [wan_link0] Link: Join bundle "wan"
Jan 2 13:26:42ppp: [wan] Bundle: Status update: up 1 link, total bandwidth 64000 bps
Jan 2 13:26:42ppp: [wan] IPCP: Open event
Jan 2 13:26:42ppp: [wan] IPCP: state change Initial --> Starting
Jan 2 13:26:42ppp: [wan] IPCP: LayerStart
Jan 2 13:26:42ppp: [wan] IPCP: Up event
Jan 2 13:26:42ppp: [wan] IPCP: state change Starting --> Req-Sent
Jan 2 13:26:42ppp: [wan] IPCP: SendConfigReq #5
Jan 2 13:26:42ppp: [wan] IPADDR 0.0.0.0
Jan 2 13:26:42ppp: [wan] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid
Jan 2 13:26:42ppp: [wan] PRIDNS 0.0.0.0
Jan 2 13:26:42ppp: [wan] SECDNS 0.0.0.0
Jan 2 13:26:42ppp: [wan] IPCP: rec'd Configure Request #65 (Req-Sent)
Jan 2 13:26:42ppp: [wan] IPADDR 217.32.147.2
Jan 2 13:26:42ppp: [wan] 217.32.147.2 is OK
Jan 2 13:26:42ppp: [wan] IPCP: SendConfigAck #65
Jan 2 13:26:42ppp: [wan] IPCP: state change Req-Sent --> Ack-Sent
Jan 2 13:26:42ppp: [wan] IPCP: rec'd Configure Reject #5 (Ack-Sent)
Jan 2 13:26:42ppp: [wan] IPCP: SendConfigReq #6
Jan 2 13:26:42ppp: [wan] IPCP: rec'd Configure Nak #6 (Ack-Sent)
Jan 2 13:26:42ppp: [wan] IPADDR 86.174.161.72
Jan 2 13:26:42ppp: [wan] 86.174.161.72 is OK
Jan 2 13:26:42ppp: [wan] PRIDNS 213.120.234.6
Jan 2 13:26:42ppp: [wan] SECDNS 62.6.40.162
Jan 2 13:26:42ppp: [wan] IPCP: SendConfigReq #7
Jan 2 13:26:42ppp: [wan] IPCP: rec'd Configure Ack #7 (Ack-Sent)
Jan 2 13:26:42ppp: [wan] IPCP: state change Ack-Sent --> Opened
Jan 2 13:26:42ppp: [wan] IPCP: LayerUp
Jan 2 13:26:42ppp: [wan] 86.174.161.72 -> 217.32.147.2
Jan 2 13:26:43ppp: [wan] IFACE: Up event
Message 10 of 19
BT only use ppp0A unless you are an infinity user
