howdy
Message 1 of 3
Slow speed at night
Hi I joined bt on the 21st jan 09 all ok for a few days.
My speed is running at 6 meg during the day but from about five o'clock at night the speed drops to about 1-2 meg and then goes back to the Meg about O'clock.
Mi on option 3
not running an extension cable
connected to the master socket
I plate fitted
any help would be grateful as the speed issue is starting to get very annoying now.
2 REPLIES 2
Guru
Message 2 of 3
Re: Slow speed at night
You can expect a reduction in throughput during the peak hours, it's to be expected.
Although to try and spot anything more sinister you need to post more information, like your hub stats and the results of a BT tester line test, preferably for both scenarios.
howdy
Message 3 of 3
here are my router statsil post speed test result tonight as i only have speed problems at night
ADSL line status<script type="text/javascript"></script>
Connection information<script type="text/javascript"></script>
Line stateConnected
Connection time2 days, 12:32:26
Downstream7,648 Kbps
Upstream448 Kbps
ADSL settings<script type="text/javascript"></script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)7.7 dB / 21.0 dB
Line attenuation (Down/Up)36.0 dB / 19.5 dB
Output power (Down/Up)19.8 dBm / 12.2 dBm
Loss of Framing (Local)3
Loss of Signal (Local)1
Loss of Power (Local)0
FEC Errors (Down/Up)846952 / 3
CRC Errors (Down/Up)1784 / 2147480000
HEC Errors (Down/Up)nil / 2
Error Seconds (Local)1293
