leeham38
Newbie
Message 1 of 7
Slow speed for the past week
Hey
Not sure why but I have been getting incredibly slow speeds in for just over a week now. I live alone so am the the user of the only PC / Laptop in the building. The slow speed is affecting both my PC which is wired and my Laptop which uses wireless.
The connection speeds are slow regardless of the time of day. Being someone who streams videos on Youtube or Iplayer often I now have to wait for even a 240p video to buffer before I can watch the video.
So far I have tried:
Using the test socket to see if that helped.
Changing WiFi channel and encryption from WEP to WPA.
Resetting the home hub to its default settings.
None of these attempts have been successful, if there is anything anyone can suggest to try, I would be grateful.
Leeham38
6 REPLIES 6
Message 2 of 7
Re: Slow speed for the past week
can you post the adsl stats from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester http://speedtester.bt.com and post the results.
I would reconnect to the test socket if you have extension phone sockets in your home as this will eliminate any noise caused by your internal wiring
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone
Someone may then be able to offer help/assistance/suggestions to your problem
chris6273
Recognised Expert
Message 3 of 7
Hi leeham38, Welcome to the Forums 🙂
Please could you post your line stats using the steps found here: http://www.kitz.co.uk/adsl/frogstats.php
This will help us determine the problem.
Thanks 🙂
Edit: haha beat me to it, imjolly Smiley Very Happy
___________________________________
Like this post? Give it a Star :D. If this post answers your question, please Mark it as the Accepted Solution.
leeham38
Newbie
Message 4 of 7
Connection information
Line stateConnected
Connection time0 days, 2:37:24
Downstream18,385 Kbps
Upstream1,276 Kbps
Test1 comprises of two tests
1. Best Effort Test:
Download Speed
338 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 338 Kbps
 For your connection, the acceptable range of speedsis 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :18385 Kbps(DOWN-STREAM), 1276 Kbps(UP-STREAM)
 IP Profile for your line is - 16000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 0.22:7.12:92.94 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test:  -provides background information.
Upload Speed
263 Kbps
0 Kbps1276 Kbps
>Upload speedachieved during the test was - 263 Kbps
 Upstream Rate IP profile on your line is - 1276 Kbps
SpeedTest.net Result :   http://www.speedtest.net/result/1225051594.png
Message 5 of 7
check your exchange here for problems http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
if ok then contact the mods for assistance http://bt.custhelp.com/app/contact_email/c/4951
leeham38
Newbie
Message 6 of 7
Thanks. Sent off a contact form to the mods. Something cant be right when your getting :
Message 7 of 7
looks like an exchange problem with such a low throughput.
mods will get back to you but might take 2/3 days
