crd1993
Message 1 of 66
Slow speed whilst gaming? Any help
So i recently moved to wales and we got BT all set up However whilst gaming online (planetside 2 and steam games)
i get horrific lagspikes for about 10-20 seconds then it settles down it happens for a while of about 5 minute intervals then will quieten down for a bit longer but It's really starting to become quite an annoyance.
My download speed is 5.7 according to speedchecker however my upload is only 0.15 Which seems really low Can nayone offer advice on what to do?
ADSL Line Status
Connection Information
line state:Connected
Connection time:2 days, 02:28:01
Downstream:7.938 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):10.8 dB / 22.0 dB
Line attenuation (Down/Up):36.8 dB / 21.0 dB
Output power (Down/Up):19.9 dBm / 11.9 dBm
FEC events (Down/Up):0 / 0
CRC Events (Down/Up):1024 / 13
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):674 / 0
Error Seconds (Local/Remote):611 / 11
65 REPLIES 65
Message 2 of 66
Re: Slow speed whilst gaming? Any help
your stats look fine for 2+ days connected with max speed for an adslmax connection.  can you run btspeedtester and post the results please
crd1993
Message 3 of 66
Download speed 6.41
uploadspeed 0.05
latency 76.50
Whilst using teamspeak other pepole don't lag for me but i lag when trying to speak/use actions on games so im guessing my upload speed is the problem
i will also mention that im using a wired connection and my exchange is only one mile away
Message 4 of 66
Could you please run the diagnostic part of the BT speed test also are you using a wired or wireless connection to your hub?
crd1993
Message 5 of 66
Im currently using a wired connection
And it says
Connection speed 8.13mb
Download speed 6.62
upload speed 0.36mb
Message 6 of 66
these results look ok for an adslmax connection
crd1993
Message 7 of 66
Thats what i don't get It doesnt appear to be the wiring from the exchange to my house but something inside my house thats causing the problem i looked at the Iterference tips and have now moved my router away from the phone and anyother electrical device just trying to rule out possabilities as i really am failing to understand how my latency on games is so bad.
Message 8 of 66
if you have now moved router away from electrical interference including the christmas lights then see how it goes tonight - mind you Santa's sleigh may interfere as it goes over your houseSmiley Wink
crd1993
Message 9 of 66
haha maybe but just hoping for anything at the moment really starting to become an annoyance am tempted to ring bt but not much they can do over christmas i guess
crd1993
Message 10 of 66
only problem is that it still says my upload speed is 0.03 which is in my opinion ridiculous on the bt speedtester
