andybeattie
Message 1 of 5
Slow speed
My Broadband normnally runs at 6.5Mbps download and about 0.5 up. For the last thre days I been getting the result below:
 Download speedachieved during the test was - 0.09 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 7.15 Mbps
If I reset my roputer I get 6.5 Mbps for a few seconds then the line slows down rapidly to the above. My router details are below. I am not using the home hub but a Draytek 2820n. Any advice would be appreciated, or a reset of the line for me 🙂
Andy
Online Status
Physical Connection System Uptime: 2days 20:35:42
LAN StatusPrimary DNS: 213.120.234.34Secondary DNS: 213.120.234.2
  IP AddressTX PacketsRX Packets
  192.168.1.192975175672780
WAN 1 Status>> Drop PPPoA
  EnableLineNameModeUp Time
  YesADSLBT InternetPPPoA0:56:12
  IPGW IPTX PacketsTX Rate(Bps)RX PacketsRX Rate(Bps)
  31.50.244.143217.47.66.141203078452331958818208
WAN 2 Status
  NoEthernet ---00:00:00
  ------0000
ADSL Information       ( ADSL Firmware Version:  232201_A)
  ATM StatisticsTX CellsRX CellsTX CRC errsRX CRC errs
  10115963921986679520
  ADSL StatusModeStateUp SpeedDown SpeedSNR MarginLoop Att.
  G.DMTSHOWTIME4480008128000920
4 REPLIES 4
Message 2 of 5
Re: Slow speed
your connection is the best you can get for adsl max and there is nothing to reset
Is anything showing here for your exchange http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
Message 3 of 5
Re: Slow speed
Have you tried a new filter if no exchnage problems?  Do you use an phone extension cable to reach the test socket?
andybeattie
Message 4 of 5
Re: Slow speed
Whatever had happened to the line seems to have cleared now and I have a download of 6.9 Mb/s and up load 0.69.
Andy
Message 5 of 5
Re: Slow speed
Thats good
your upload at 0.69 is to high as connection speed is only 448kbps
