Message 1 of 7
Slow sync after moving extension socket
IMG_1707.PNGFor the 2 years I've lived in this house my connection has synced at the full 79mb of Infinity 2 and the HH5 has always been plugged into an extension socket.
I wanted to move the extension socket somewhere else so picked up some CW1308 cable and moved it.
When I fired up the HH5 it synced at just 31mb and the noise margin is at 6.5 which tells me that's the best it could get.
What did I do wrong? I am running the CW1308 very close to electrical cable, could this be interfering? Would cat5e be a better choice for the extension?
6 REPLIES 6
Webby
Message 2 of 7
Re: Slow sync after moving extension socket
Dodgy crimp, poor cable or something interfering.
Message 3 of 7
Thanks Webby
i suspect it's interference from the mains electrical cable it's running alongside
Is there a more suitable extension cable I could use instead?
Webby
Message 4 of 7
Could you not leave it where it was and use wireless/homeplugs or a mixture?
Message 5 of 7
IMG_1708.PNGRe-routed the cable away from the mains electrics and we are back in business, thanks for your help Webby
RogerB
Guru
Message 6 of 7
Seems you've awakened the attention of the fire dragon.
Message 7 of 7
Fire dragon what
