woodse
Message 1 of 14
Slow upload after exchange upgrade
Dear all
I'm very grateful for any help.  I am connected to the Woolhampton exchange near Reading in Berkshire.  I live quite a long way from the exchange so am realistic about connection speeds.
Until recently I got just under 2meg download and about 400k or so upload, which wasn't great but was ok for work.
Recently (in late January, I think), the Woolhampton exchange was upgraded to 21CN networks (?). Since about this time my upload speed has collapsed and I now have a profile of 128k but am not even getting this much.
I am nervous about asking BT to investigate for fear they will slow down my download speed - I depend on the internet to send and receive a lot of large documents for work.  However the upload speed is now so slow that it takes several minutes to send an email with an attachment.  I really dont' want the download speed slowed any more!
My stats from the BT speedtester are here:
Download speedachieved during the test was - 1892 Kbps
 For your connection, the acceptable range of speeds is 400-2000 Kbps.
 Additional Information:
 Your DSL Connection Rate :2432 Kbps(DOWN-STREAM), 128 Kbps(UP-STREAM)
 IP Profile for your line is - 2000 Kbps
My stats from my router are here
ADSL Link
Downstream
Connection Speed 2432 kbps
Line Attenuation 58.0 db
Noise Margin 11.1 db
Upstream
 Connection Speed 128 kbps
Line Attenuation 30.5 db
Noise Margin 6.0 db
System Up Time 215:33:35
Port LAN
Status 10M/100M
TxPkts 1063028
RxPkts 644691
Collisions 0
Tx B/s 1177
Rx B/s 186
Up Time 215:33:31
Thank you very much for your help
Best wishes
Edward
13 REPLIES 13
gouldyyyy
Message 2 of 14
Re: Slow upload after exchange upgrade
It does not look as though your line has been upgraded, your exchange may have been upgraded but your line probably won't be done for another few months unless you re-contract.  You can check what speed you should be able to get here http://bit.ly/yJGwdX.  Regardless the upload speed is still far below what it should be.
What type of master socket are you using?
and also what router are you using?
woodse
Message 3 of 14
Thank you very much for replying.  I have an openreach NTE5 socket. It was installed in the house (new connection as new house) in May 2010 and we had a year an half of a higher speed profile than this.  The router is a Netgear DGN2000 - interestingly at about the time the connection slowed I could get no wired connection from the router, although WIFI was fine.  I restarted it and the wired connection has recovered.  Thank you, Edward
john46
Message 4 of 14
hi could you please repost your latest speed test results and hub stats
gouldyyyy
Message 5 of 14
If you unscrew the lower half of the front of the master socket and connect to the test socket can you then post what your circuit sync is?
woodse
Message 6 of 14
Here are the latest speedtester results
Download speedachieved during the test was - 1855 Kbps
And here are my router stats
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANPPPoA998264136868902661709223:35:14
LAN10M/100M109743366668601166184223:36:49
WLAN11M/54M/130M7574605135880733154223:36:23
ADSL LinkDownstreamUpstream
Connection Speed2432 kbps128 kbps
Line Attenuation58.0 db30.5 db
Noise Margin10.8 db6.0 db
Where do I find the circuit sync - the router is conntected by a 30 cm wire into the master socket (and then split ADSL and voice and the voice does three lines via a patch panel).
gouldyyyy
Message 7 of 14
SOrry, the circuit sync is the same as posting your adsl stats :$. So you do have the Service Specific Faceplate, which is the main socket you connect to? If you unscrew this then you should be able to connect to the test socket at the back of this, you will however require a micro filter. My bench is to seem you have something like a HR fault purely from experience where the upstream is that low.
If you go too this link and just type in your postcode http://www.samknows.com/broadband/broadband_checker it should tell you how far you are from the exchange, can you please let me know how far you are?
woodse
Message 8 of 14
I couldn't get the stat from Samknows but to drive (it's wiggly back country lanes) to the exchange is about 4 miles.
I'll plug into the test socket in an hour or so when I get the chance.
Thanks again
Webby
Message 9 of 14
To echo Gouldy....
You need to test into the test socket. The speeds haven't changed from your first test to the second. If when you've removed the front plate and connected to the test socket the speeds are still the same then it looks like an engineer visit will be needed.
woodse
Message 10 of 14
I have now plugged into the test socket and got 448 upload again
System Up Time 224:28:59
WANPPPoA254015200:00:59
LAN10M/100M111337767887601178186224:28:55
WLAN11M/54M/130M7615995171310732155224:28:29
Connection Speed2240 kbps448 kbps
Noise Margin12.0 db17.0 db
Now I need to find the fault in my patch panel, I suppose?
Thanks all for your help - hugely appreciated
Edward
