Vanquishor
Message 1 of 8
Slow upload speed and random disconnects
Hello everyone,
I've joined the forum as I've had issues with my internet recently and I seem to be going around in circles with the BT call centres.
For about 2 weeks now, my upload speeds have been really slow (0.38mb max) and my HH has been losing connection a few times a day.  It generally reconnects after a minute or so.  I first noticed it whilst online gaming, having bad lag being frequently disconnected from matches.  I subsequently noticed that skype video calls were impossible as the quality and constant break up of the call were too frustrating.
I dont often use my landline, so when I did to contact BT there was a crackle on the line and they suggested this was the reason behind my slow upload and it was probably being caused by a faulty microfilter.  A new microfilter replaced the old one, same problem.  I carried out the usual procedure of connecting the HH to the master socket but the problem persisted.  So they then suggested that the HH was the problem.
The new HH has pretty much (as far as I can tell) eliminated the crackle on the line but the slow upload speeds persist as well as the disconnects.  I have now put the new HH on the master socket again to see if the disconnects continue.  So far I've had 10hrs without a disconnect but my upload speed still won't go above 0.38mb which is really slow considering I my down is between 10-16mb.
Any ideas on whats causing the slow uploads?
BT have booked an engineer to come out in the new year because of the previous reported crackle but as the crackle has all but disappeared I'm slightly reluctanct as I know BT will charge me if they come over and don't find the crackle.
Do my line stats below shed any light on what might be causing the slow uploads?
Apologies for the really long post.
Robert
Here are my stats as of now:
Line state:
Connected
Connection time:
0 day, 10:00:15
Downstream:
17,927 Kbps
Upstream:
448 Kbps
ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.5 Annex A
Latency type:
Fast
Noise margin (Down/Up):
5.9 dB / 30.3 dB
Line attenuation (Down/Up):
13.0 dB / 6.8 dB
Output power (Down/Up):
20.9 dBm / 11.8 dBm
FEC Events (Down/Up):
0 / 0
CRC Events (Down/Up):
482 / 297
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
HEC Errors (Down/Up):
1543 / 99
Error Seconds (Local/Remote):
0 / 287
7 REPLIES 7
Vanquishor
Message 2 of 8
Re: Slow upload speed and random disconnects
Forgot to mention that I live approximately 500 metres from the exchange.
imjolly
Message 3 of 8
is the crackle there when you do quiet line test from test socket?  have you tried connecting the router to the test socket with the new filter as this will eliminate all your internal wiring and see if this improves your connection
Vanquishor
Message 4 of 8
Thanks for the reply.
I dont actually have a test socket as my master socket is one of the old 68mm ones. I have run a quiet line test at the master socket and I couldn't hear any crackling.
john46
Message 5 of 8
It looks like the wrong up speed profile may have been applied to the line The forum mods would be able to investigate it for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days maybe longer of course due to Christmas they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderator
Vanquishor
Message 6 of 8
Thanks for the link.  I've just checked my line stats again and my upload has increased but I was disconnected about 5 hrs ago.  Also, what sort of upload speed should I be averaging?  I've never realy paid much attention to my upload speed before as evrything worked but as my download is pretty high, even 0.92 upload seems quite low.
Here are my line stats as of now:
ADSL Line Status
Connection information
Line state:
Connected
Connection time:
0 day, 04:48:29
Downstream:
17,994 Kbps
Upstream:
1,078 Kbps
ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.5 Annex A
Latency type:
Interleaved
6.1 dB / 5.2 dB
13.0 dB / 6.8 dB
20.8 dBm / 12.2 dBm
618458 / 368
1 / 563
0 / 0
0 / 0
0 / 0
0
34 / 425
0 / 533
imjolly
Message 7 of 8
your upload speed is fine for 21CN - 1000/1100 is what I normally get
john46
Message 8 of 8
that is now back to normal just keep an eye on the stats for a few days to see if it changes again then if it dos use the link
