-Darren-
Message 1 of 5
** Slow upload speed to hotfile.com **
Getting sub 1Mb upload speed to hotifle.com for the last few weeks, it's got worse and worse. Usual speed is ~14Mb.
Hotifle tell me they aren't throttleing speeds and my connecition is otherwise running at line speed.
Can a mod please look into this.
4 REPLIES 4
-Darren-
Message 2 of 5
Re: ** Slow upload speed to hotfile.com **
It's hit the floor now, this small file should take 3 mins but at this rate it will take an hour.. 37KB/s average.
(Click image for full size)
sjtp
Guru
Message 3 of 5
If you want a mods attention you should ask explicitly at: http://bt.custhelp.com/app/contact_email/c/4951 . But be aware they take 3 working days to reply: sometimes more if busy.
They'll need more information you might as well post here:
Run the speedtest at http://speedtest.btwholesale.com/ and after the test choose ‘Further Diagnostics’ and post the speeds and the profiles that this gives.
Run a test to speedtest.net.
Run a command line call   tracert hotfile.com  and post the result.
-Darren-
Message 4 of 5
I contacted the mods immediately after posting this topic, still waiting for a reply I suppose they are busy.
If I use a proxy uploads run at 12Mb/s, a considerable improvement.
Downloads from hotfile are between 20-72Mb/s which I find odd. If it was a congested link I'd expect downloads to be slow too. Are BT throttleing hotfile uploads.
Like I say the connection is otherwise running at line speed.
C:\Documents and Settings\Administrator>tracert hotfile.com
Tracing route to hotfile.com [199.7.177.224]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.1.2
  2     5 ms     5 ms     5 ms  213.120.155.227
  3     5 ms     5 ms     5 ms  213.120.155.142
  4     6 ms     6 ms     6 ms  217.41.216.226
  5     5 ms     6 ms     6 ms  31.55.164.229
  6     6 ms     6 ms     6 ms  31.55.164.109
  7     6 ms     6 ms     6 ms  acc2-10GigE-0-2-0-4.bm.21cn-ipp.bt.net [109.159.248.232]
  8    17 ms    15 ms    15 ms  core2-te0-3-0-3.ealing.ukcore.bt.net [109.159.248.150]
  9    10 ms    10 ms    10 ms  peer2-xe10-1-0.telehouse.ukcore.bt.net [109.159.254.116]
 10    10 ms    10 ms    10 ms  166-49-211-182.eu.bt.net [166.49.211.182]
 11    11 ms    11 ms    11 ms  peering.linx.eu.iptransit.com [195.66.225.106]
 12    88 ms    93 ms    87 ms  xe-0-1-1.r1.ny.us.iptransit.com [204.26.60.210]
 13   118 ms   118 ms   117 ms  te8-8.r3.dal.us.iptransit.com [204.26.60.62]
 14   118 ms   117 ms   117 ms  te3-4.r1.dal.us.iptransit.com [204.26.61.5]
 15   118 ms   117 ms   117 ms  204.26.60.158
 16   125 ms   124 ms   125 ms  w9.hotfile.com [199.7.177.224]
Trace complete.
john46
Message 5 of 5
the mods will normally reply to you personally within 3 Working days
