Which router are you using at the moment, and what is the upload and download connection rate showing?
Also the upload and download noise margin. How does it compare to the last values you posted?
@confusedgirl100 wrote:
My router is a TP Link VR900.
Download speed is on average 2.5mbs. Upload speed usually 900kps, however it drops to 100-200kps overnight.
I haven't changed my connection set up since installing my new router. I've replaced the adsl filter just in case this may be the issue.
Any advice would be appreciated.
What is the actual connection speed as shown on the router, that is the important figure.
post the connection stats from your tplink
Hi Keith/imjolly,
Sorry for the delay but I haven't had a chance to post the actual stats.
Here's the most recent stats from my TP Link Router.
DSL UP Time: 1 day 8 hours 37 minutes
Upstream Downstream
Current rate 126 kbps 2265 kbps
Max rate 196 kbps 4160 kbps
SNR margin 12.4 db 5.4 db
Line attenuation 33.7 db 57.5 db
Errors 55695 pkts 105081 pkts
After disconnecting the ADSL filter from the phone line extension and reconnecting it, the new stats are as follows:
DSL Up time: 0 days 1 hour 22 minutes
Upstream Downstream
Current rate 937 kbps 2268 kbps
Max rate 968 kbps 3832 kbps
SNR margin 6.2 db 9.3 db
Line attenuation 33.4 db 57.5 db
Errors 55704 pkts 105566 pkts
Any advice as to why the upstream/upload rate is dropping would be much appreciated.
Thanks in advance.
The upstream rate has increased to what I would expect it to be, and the downstream rate is about right, but you are showing a lot of errors on the line, which could be due to a noisy phone line. In theory, you should be getting a connections speed nearer to the max data rate, but I suspect the errors are preventing that.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements
Hi Keith,
Thanks for your reply.
I tried the quiet line test and there was no noise on the line.
Is there anything specific that could be causing the errors on the line?
Thanks in advance.
Hi Keith,
Thanks in advance.
Its probably just general high frequency noise causing the errors, there is not much you can do about it on such a long line.
Your actual speed is quite good, considering the distance you are from the exchange.
This is the result from the Kitz site, using your attenuation. The best download you could expect under ideal conditions, would be 3488Kbs.
As your upload speed is actually very good for your line length, then any noise pickup must be only affecting the download frequency band, which is common, as I expect there is a long section of overhead cable along the route.
I assume you only have a single phone socket, and no extensions?
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
