Message 1 of 5
Slow upstream on BT superfast
Hi BT,
An issue I had in Dec 19 with my BT Superfast Fibre 1 has recurred.
My upload speed has slowed to a consistent 2.8 Mbps from a normal of 7.5 Mbps in the past 2 months. The slow upload is consistent and does not ever increase outside of busy hours. I have done the usual fault finding: reset; router swap; direct cabling and socket bypass. The line test reports no noise. Download speed is unchanged at circa 45 Mbps.
Help please.
Pete
4 REPLIES 4
Message 2 of 5
Re: Slow upstream on BT superfast
can you post hub stats if hh6 then advanced settings then technical log information
enter your phone number and post results    https://www.dslchecker.bt.com/adsl/adslchecker.welcome
any line noise  dial 17070 option 2  should be silent and best with corded phone
Message 3 of 5
Hi - 2 x screenshots attached.
Thanks,
Pete
Message 4 of 5
Hi - the line still tests quiet.
Pete
Message 5 of 5
Hi @PeterY1, thanks for posting, looking at the checker results your line should expect an upload of between 5.9Mb to 8.9M and your download speed looks perfect. I'll send you over a Private message and the moderation team will be happy to take a look.
