JoeP
Message 1 of 18
Slow
Hi,
My engineer came to install my BT Unlimited faster (Fibre optic but not branded infinity right?)
He did a very good job i must say.
I asked him how fast it should be, he said 18mb download and 1 upload.
At the moment it is running at 5mb download, will this start to increase throught the week?
If it doesn't, what shall i do?
Thank you.
17 REPLIES 17
john46
Message 2 of 18
Re: Slow
are you using a wired or wireless connection when you checked your speed
can you please run the BT speedtest further diagnostic test this test appears after the first test completes and post back the results
http://speedtest.btwholesale.com/
JoeP
Message 3 of 18
Re: Slow
Best Effort Test:
Download Speed : 5.73 Mbps
2. Upstream Test:
Upload Speed : 0.97 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information
john46
Message 4 of 18
Re: Slow
wired or wireless connection ?
JoeP
Message 5 of 18
Re: Slow
similar on both
ray_dorset
Distinguished Guru
Message 6 of 18
Re: Slow
Do you have a Homehub 5 ?
If not, I'll try again 🙂
JoeP
Message 7 of 18
Re: Slow
yes.
john46
Message 8 of 18
Re: Slow
can you post back the details from this checker editing out your phone number http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput
ray_dorset
Distinguished Guru
Message 9 of 18
Re: Slow
Can you post your line stats from Troubleshooting/Helpdesk on the HH5 at http://192.168.1.254 please
Lines 1-13 will be enough
JoeP
Message 10 of 18
Re: Slow
FTTC Range A (Clean) 18.5 12.6 1.2 0.8 -- Available
FTTC Range B (Impacted) 15.5 7.7 1 0.6 -- Available
WBC ADSL 2+ Up to 7 -- 6 to 8 Capacity expected 10 August 2014
ADSL Max Up to 7 -- 6 to 8 Available
WBC Fixed Rate 2 -- -- Available
Other Offerings
Fibre Multicast -- -- -- Availa
