JoeP
Message 11 of 18
Re: Slow
1. Product name: BT Home Hub
2. Serial number: +068343+NQ41731480
3. Firmware version: Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown
4. Board version: BT Hub 5A
5. VDSL uptime: 0 days, 01:06:24
6. Data rate: 1101 / 6020
7. Maximum data rate: 1096 / 6088
8. Noise margin: 5.9 / 6.0
9. Line attenuation: 0.0 / 30.9
10. Signal attenuation: 0.0 / 22.9
11. Data sent/received: 22.4 MB / 214.7 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
ray_dorset
Distinguished Guru
Message 12 of 18
Re: Slow
Looks like your installer messed up the install. I think you should complain
If not, I'll try again 🙂
JoeP
Message 13 of 18
Re: Slow
Really? How so?
JoeP
Message 14 of 18
Re: Slow
What has he messed up and what shall i say when i complain?
ray_dorset
Distinguished Guru
Message 15 of 18
Re: Slow
You said he told you you would get 18Mbps - when they do the install that information is given to them on an app they run on their device.
The missing 12Mbps is due to the faulty install.
JoeP
Message 16 of 18
Re: Slow
So i pay 45 sodding pounds a month for a bad install, how ridiculous!
JoeP
Message 17 of 18
Re: Slow
UPDATE
I rang up and complained and they are sending me out a new hub.
if the problem still exists will they sort it out for me?
pippincp
Message 18 of 18
Re: Slow
You need an engineer out to sort out your install as there is a problem somewhere.
