Message 1 of 22
Slower speeds than guaranteed?
Hey guys,
I've been with BT for some yrs...I moved to a new property last yr and the connection was horrendous there, I was getting 3-4mbps but was guaranteed 10mbps, no fibre was available there. BT told me theres nothing they could do because I was about 1500 meters from the cabinet.
Long story short, I work from home and fast broadband is absolutly necessary. Last month I moved again to a property where estimates showed 69mbps with minimum guaranteed 49mbps. I got the connection and still I am getting 32mbps max.
An engineer visited and found no issues with the line. My house is 450m from the cabinet, here is the test result.
I've seen posts here where people were getting over 70mbps at 450m or even at 500m.
Is 32mbps max speed i could get here?
21 REPLIES 21
Message 2 of 22
Re: Slower speeds than guaranteed?
can you post stats from your router
enter your phone number and post results  remeber delete number  http://dslchecker.bt.com/adsl/adslchecker.welcome
Message 3 of 22
Thanks for your reply, here are the results...is there something wrong with their equipment?
Message 4 of 22
stata from your router please
Message 5 of 22
BT engineer that installed the line told me cabinet is 450m from my house.
Message 6 of 22
Stats?
How to check that?
Message 7 of 22
Screen Shot 2018-03-06 at 17.01.58.pngI have Infinity 2, they lowered the monthly cost but told me I'll still get inifinity 2 speeds.
Message 8 of 22
Estimates are showing 77mbps now but I am getting 32mbps.
Message 9 of 22
as hh6 can you go to advanced setting then technical log information and post the information
Message 10 of 22
You want to see the event logs?
