andyarran
Newbie
Message 1 of 8
Slowest ADSL ever.
Hello,
I've just had my phone line and ADSL enabled today but it seems to be the slowest ADSL ever. I know there is meant to be a stablisation period of 10 days but surely it shouldn't start off this slow. I've checked in the Hub Settings and it says this:
Surely it's not set to be at 128Kbps?
Every speed tester says its around 0.05 or 0.10 kbps...
Any advice or do I need to wait 10 days before they can do anything?
Connection Information
Line state:Connected
Connection time:0 days, 02:56:23
Downstream:128 Kbps
Upstream:64 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):31.7 dB / 31.0 dB
Line attenuation (Down/Up):27.0 dB / 14.0 dB
Output power (Down/Up):4.8 dBm / 2.9 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):0 / 1
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 0
Error Seconds (Local/Remote):
0 / 1
7 REPLIES 7
Message 2 of 8
Re: Slowest ADSL ever.
are you connected to the test socket? or have you tried the test socket?
Guru
Message 3 of 8
I think that's just about the worst noise margin I've ever seen on a new Max line.
I'm dubious.  And think I'd push for a line profile reset, training or not.   😉
But as an add-in to the OP, hope you clearly know you must not hinder the training period ....
And as IMJ has said .... you maybe need to go into the test socket to prove a point.
Strange.
andyarran
Newbie
Message 4 of 8
Hello,
Just thought i'd post an update. It seems to have increased in speed today. Hopefully it'll get up to a speed closer to 8 Mbps. The BT speed checker says the line profile is set to 2Mbps and currently connecting at around 1.5Mbps so hopefully it'll increase if i leave the router turned on.
Thanks for your help.
ADSL Line Status
Connection time:0 days, 10:37:07
Downstream:7.938 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):10.9 dB / 22.0 dB
Line attenuation (Down/Up):27.1 dB / 14.0 dB
Output power (Down/Up):19.8 dBm / 12.0 dBm
CRC Events (Down/Up):179 / 0
HEC Events (Down/Up):279 / 0
Error Seconds (Local/Remote):165 / 3
Message 5 of 8
that's max speed for adslmax and now just need to leave connection 24/7 and profile should rise from 2mb to 7.15mb.  keep checking as it can sometimes get stuck at 2mb and you need mod help to fix it
andyarran
Newbie
Message 6 of 8
Thanks for that Imjolly.
Will keep an eye on it.
andyarran
Newbie
Message 7 of 8
Just thought i'd post the update to show my speed went up by itself. I restarted my router after plugging it into the test socket (just incase).
Today it's at:
Download speed achieved during the test was - 6.49
Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional
Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM),
0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
ADSL Line Status
Connection time:1 days, 19:21:05
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):11.0 dB / 23.0 dB
Line attenuation (Down/Up):27.2 dB / 13.5 dB
Output power (Down/Up):19.8 dBm / 11.8 dBm
CRC Events (Down/Up):1324 / 3
HEC Events (Down/Up):967 / 0
Error Seconds (Local/Remote):887 / 4
Message 8 of 8
You see, imjolly was right, its a very common issue Smiley Wink
