In the last week my broadband (fibre) speed has dropped to 8mb/s and the recently obtained Smart Hub 2 is taking around 15 minutes to boot up.
Browsing and P2P transfers are fine, but uploads to Cloud or Dropbox fail due to lost connection.
Any help or suggestions (in words of one syllable) greatly appreciated.
Thanks in advance.
Post hub stats. Advanced settings then technical log information
check for line noise. Dial 17070 option 2 should be silent and best with corded phone
enter phone number and post results remember delete number. https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Sounds like a disconnection on one wire. If that is the case then there will be no dial tone on the phone.
Why is your hub needing to boot up? Routers are intended to be powered 24/7
Are you switching hub off at night and on again in the morning?
hub stats?
@imjolly Hub stats. Have always switched router off overnight.
As already said the hub is designed to remain connected 24/7 and not off at night and on again in morning. That can have an adverse affect on your connection as it can appear as an unstable connection
