Hey I was supposed to be upgraded to full fibre last week but there’s been complications which will take weeks to sort.
I have the smart hub 2 sitting here so I decided to plug it in. It doesn’t work.
Lots of posts suggest it should work with fttc even though it has the Fibre port.
Any ideas? Cheers.
Welcome to this user forum.
You would need to use the DSL connection, which I think is present on both versions. Its to the left of the picture next to the phone port and below the label. You need an RJ11 lead, which you may be able to take from your existing BT home hub.
