Message 11 of 143
Re: Smart Hub 2 Wi Fi devices are dropping connection and reconnecting
Update: I am getting nowhere by swapping 2.4 and 5GHz channels. I am still seeing a fairly regular dropping out of the wifi, and then within 30 seconds or so my laptop shows it has auto logged on to the wifi channel again.  I contacted BT and they also can see a log of drops in wifi once a day - although I am experiencing it more frequently when browsing.
I did a full factory rest of the Smart Hub 2. That doesn't seem to have improved things.  It has also flagged (when logging on to the wifi in Settings on an iPhone) that "this network is blocking encrypted DNS traffic".     I have not seen this alert on my own WiFi network before.  Can anyone help me and explain what this means and if I should tweak my router settings back to how they were? (I assume the reset lost my optimal settings)
BT Smart Hub 2 + BT Disc on full fibre 150Meg Halo FTTP
Macs and iphones, plus alexa, YouView box, Amazon Fire TV, Apple TV+
CFP project lead.
Message 12 of 143
The log error that sticks out is repeated often:
5G Client disassociate from 56:7b:a7:cf:8c:99 (IP=192.168.1.98) RSSI=0, Rate=0Mbps
CFP project lead.
Anonymous
Not applicable
Message 13 of 143
Try giving the laptop a static IP address. I believe the DHCP range for the Smart Hub 2 starts at 192.168.1.64, so any address below this will take DHCP out of the equation.
Message 14 of 143
Update:
I swapped out the Smart Hub 2 for a new one sent by BT. That sorted out the issue for a short while, but overnight the firmware autoupdated to v0.31.00.10253-BT and from then on it seems the issues continue - the regular loss of wifi for 3 seconds or so.
CFP project lead.
Message 15 of 143
My woes continue.  I have done a complete swap out of the Smart Hub 2, and taken the BT Disc out of the network. Both 2.4GHz and 5GHz are on. Smart setup is off, and smart channels are off.
My regular 3 - 5 second loss of wifi continues... even to the point of posting on this forum stalled and required a refresh. The log for that event is here repeating 7 times:
16:44:42, 07 Mar. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
Any thoughts on if this is a cause of loss of wifi, and what can be done to stop it?
I note someone else reported this in the BT Community Archive - the same loss of service for 3 seconds and floods of IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT.  No solution was offered then.
CFP project lead.
Message 16 of 143
@Anonymous   I put the macbook onto a manual IPv4 IP address.  However the drop outs continue.
As the Smart Hub 2 can't split the bands I tried working with just 5GHz (switching off 2.4GHz) but unfortunately some of my devices need 2.4GHz band.
CFP project lead.
Message 17 of 143
I'm having the exact same issues. I've been talking with BT for 3 weeks now. They've swapped my Smart Hub, they've checked the line and now i have a tech guru coming on Saturday. Its also affecting my wired conections too.
Message 18 of 143
@NicolasS   I'd be most interested to hear the result of your investigations.
BT phone help was sympathetic but didn't have much in the way of insight nor knowledge base on the fault... but clearly many people are having the same issue... mine is so regular that I have to refresh pages often. Like when I post here!
18:44:10, 08 Mar. admin timeout from 192.168.1.22
18:43:59, 08 Mar. DHCP device Connected: 192.168.1.69, 02:9b:36:ae:4c:ae, unknown
18:43:59, 08 Mar.5G Client disassociate from 02:9b:36:ae:4c:ae (IP=192.168.1.69) RSSI=0, Rate=0Mbps
18:43:59, 08 Mar.LAN [ADD] ARP 192.168.1.69 with 02:9b:36:ae:4c:ae from br0(wl1)
18:43:57, 08 Mar.WHW INFO A station (SmartHub2)IF[2.4G](60:8D:26:34:4B:51):STA(02:9B:36:AE:4C:AE)(Legacy Device) join WHW infrastructure
18:43:56, 08 Mar.5G client Mac: 02:9B:36:AE:4C:AE Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS)
18:43:56, 08 Mar.Self roaming might be occurring... Deauth original one...
18:43:41, 08 Mar. DHCP device Connected: 192.168.1.69, 02:9b:36:ae:4c:ae, unknown
18:43:41, 08 Mar. LAN [ADD] ARP 192.168.1.69 with 02:9b:36:ae:4c:ae from br0(wl0)
CFP project lead.
Message 19 of 143
@pmosb  no problem, I will post back on Saturday.
Same here. I can't fault them for their help, but what is causing it is a mystery.
Anonymous
Not applicable
Message 20 of 143
If you have an old Hub kicking around it might be worth trying that for a few days. Although it's highly unlikely that two SH2s would have the same fault. But having said that, I had two HH5s that randomly dropped 5GHz in the same way, so it's not impossible. But if you try a different variation of Hub & still get the same issue, it's almost certainly going to be down to your environment.
If you have DV & are tied to the SH2, you could turn off it's WiFi & DHCP server & connect the other Hub by ethernet to serve the internal network. You'll need to change the IP address of the second router away from 192.168.1.254 or it will clash with the SH2.
You could also change the WiFi SSID & password to match the SH2 so you don't have to reconnect all your clients.
