Message 1 of 5
Smart Hub 2 and BT Halo
Hi. Just got the Halo hub and am not impressed. It works on phones and iPads, but every other smart home thing will not connect. Lights, TV everything. It gets Alexa, but she can’t use them because the app can’t log onto the hub.
seriously considering unwrapping old hub and going back to it.
4 REPLIES 4
Message 2 of 5
Re: Introducing BT Halo
There is no 'Halo hub'. It just a sh2 and halo is an add-on. So you use previous hub and still gave halo
Message 3 of 5
Have you tried turning OFF "smart setup"?
Annie
BT Halo 3 (73Mb Down / 18Mb UP)
Message 4 of 5
Yes. I spoke to a BT help person and they suggested that. It didn’t work, so I unwrapped the old hub and am using that at the moment.
Message 5 of 5
@Capt_Lethargy
Most Smart Home devices currently only support the 2.4ghz band, but the Hub transmits both this and the 5G band on the same SSID.
As you can’t change the name between bands, you can disable 5ghz, see if your devices connect, and then enable it again (if you have devices that use it)
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
