Since installing my new Smart Hub 2, the 2 laptops in the household are working fine, but my Canon wireless printer does not connect, any suggestions please?
Turn off smart setup on the SH2.
Hi, Thanks for information how to reach hub manager. Just one question, when I typed my hub number ending 254 into the address bar, the site came up as "Not secure" with the advise not to use passwords, etc. Is this site safe to use?
Yes. It is because BT in their infinite wisdom still use HTTP rather than HTTPS on the hub web server page. As it is within your LAN it is perfectly safe.
Having similar problem with my I Mac not connecting for AirPrint. If I turn off smart set up and connect my I Mac to my canon printer when connected the printer has connected once do I turn smart set up back on on my smart hub 2
Really appreciate your help please
Just leave smart setup switched off as save any problems with other devices in future
Have had similar problem with Epson XP printer since BT Smart Hub2 firmware update.
Printer loses connection on my network even though shows as connected, after a reboot of my computer.
I have re set router back to factory settings then changed passwords etc back again and switched smart set up off and deleted the printer from my computer and network and reinstalled it.
Seems to be auto connecting now when I restart my computer.
Once again this morning the connection to the printer Epson XP830 failed
I disabled the 5GHz in the BT smart Hub2 and eventually got re connected on the 2.4GHz band.
However this is not really satisfactory having to separate channels purely for printing purposes.
This has only occurred since the BT Smart Hub2 had updated firmware to v0.26.03.01286-BT
who do we report this occurrence too please.
