Message 1 of 8
Smart Hub 2
Ive a HH 4 and have been sent a Smart Hub 2 (which I didn't request) as BT say they are switching over in my area so i need to change my hub.
I read that the Smart hub 2 can be controlled by an app.   Is that safe?
I'm assuming that has to be from a device connected to the wifi itself rather than controlling the hub setting remotely from anywhere?
thanks.
7 REPLIES 7
Message 2 of 8
Re: Smart Hub 2
if you are being switched to fibre then your hh4 will not work so need SH2  you can use ap but need to be on the home network to work
Message 3 of 8
Re: Smart Hub 2
Thanks for that.
So the app is basically just another way to access some of the settings.   Rather like the accessing the hub management page as i do now?
Message 4 of 8
Re: Smart Hub 2
well you need the app to add/change setting in parental control as they are no longer accessible in hub manager
Message 5 of 8
Re: Smart Hub 2
But i should be able to set the hub up in all other respects without the app?
i dont have need for the parental controls.
Message 6 of 8
Re: Smart Hub 2
@michael226, Yes that's no problem, you can install the Smart Hub 2 without the app.
Message 7 of 8
Re: Smart Hub 2
thanks that great.
I set the SH2 up today without a problem.
I did however notice the firmware version is only 0.12.02.11078 with an update date of today  - which looks like an old version.
Will it update to a newer version itself and is it ok to use whilst waiting for that?
Message 8 of 8
Re: Smart Hub 2
The latest is v0.17.01.12301-BT, it will update automatically if you leave it connected, there is no manual option to update firmware.
