PJWilkin
Message 1 of 3
Smart Hub (HH6) IPv6 not working - shows no LAN Link Local Address
I'm now on my 2nd Smart Hub (the first refused to connect to VDSL after a reboot)
The new one shows a WAN IPv6 address, but the LAN Side does not show a Link Local Address (ie it shows as 'Not Available')
Firmware on my HH6 is SG4B10002244
Anyone else had this issue ? If so is there a fix
The LAN shows a  Global unicast address , it's just the LAN Local one thats missing
As a result none of my devices have IPv6 available, and the HH6 does not show as being visible as a Neighbour to any of them
2 REPLIES 2
PJWilkin
Message 2 of 3
Re: Smart Hub (HH6) IPv6 not working - shows no LAN Link Local Address
For refernce below are screen shots (with addresses obscured)
PJWilkin
Message 3 of 3
BT Replaced the router, and issue seems fixed
looks like the Smart Hubs have lots of issues
