Message 11 of 59
Re: Smart Hub (HH6) USB port Problem
I have just upgraded from a HH3 where my WD 1 TB drive worked without a problem. It was mapped as drive Z. It appeared on my network through the HH3 as usb2(\\Bthub3) (Z:).
On the HH6 it shows 1 device in USB, but there's no way of getting to it from my network. Lets hope for a solution soon.
Recognised Expert
Message 12 of 59
It seems the Smart Hub is using a different method of authentication than the previous Home Hubs (Share-level authentication rather than User level) and this is possibly why the drives are not visible.
As a workaround, on Windows 10 at least, the USB disks seem to work OK when mapped from the command prompt. For example:
C:\Users\smf22>net view \\192.168.1.249
Shared resources at \\192.168.1.249
bthub Sharing Files
Share name  Type  Used as  Comment
Hitachi1TB  Disk           Share Hitachi1TB directory
The command completed successfully.
Note: I'm not using the Smart Hub as my router currently and so I've assigned it the IP address 192.168.1.249.
Now I know what the "share" name is i.e., Hitachi1TB, I can connect the disk as some drive letter, in my case drive h:
C:\Users\smf22>net use h: \\192.168.1.249\Hitachi1TB
And then I can see it in Windows File Explorer and from the command prompt
C:\Users\smf22>dir h:
 Volume in drive H is Hitachi1TB
 Volume Serial Number is 04A2-DBB3
 Directory of H:\
09/10/2015  02:22    <DIR>          .
01/01/2013  20:27    <DIR>          ..
01/01/2013  01:04    <DIR>          dir1
01/01/2013  01:05    <DIR>          dir2
09/10/2015  02:22    <DIR>          home
[snip]
5 File(s) 28,974,804 bytes 6 Dir(s) 999,957,737,472 bytes free
And to the earlier point that NTFS is not supported as "the firmware lacks support for NTFS like every previous hub", that statement is incorrect.
Here's the same drive connected to a Home Hub 5A:
C:\Users\smf22>net view \\192.168.1.253
Shared resources at \\192.168.1.253
BT Home Hub 5.0A File Server
USB6        Disk           (Rev: 8105)
C:\Users\smf22>dir \\192.168.1.253\usb6
 Volume in drive \\192.168.1.253\usb6 is USB6
 Volume Serial Number is 0202-004B
 Directory of \\192.168.1.253\usb6
09/10/2015  02:31    <DIR>          ..
[snip]
And again connected to a Home Hub 5B:
C:\Users\smf22>net view \\192.168.1.254
Shared resources at \\192.168.1.254
BT Home Hub 5.0B File Server
usb1        Disk           created by auto-share
C:\Users\smf22>dir \\192.168.1.254\usb1
 Volume in drive \\192.168.1.254\usb1 is usb1
 Volume Serial Number is 0202-0093
 Directory of \\192.168.1.254\usb1
03/08/2016  11:28    <DIR>          ..
[snip]
Regards
Message 13 of 59
There is a solution to this. ..I posted it a few minutes ago under the heading " file transfer USB hard drive solution".
And questions I will be happy to help
Message 14 of 59
Hi Laticsmon,
I can't find your post.
As mentioned above the drive I was using on the USB on the HH3 appeared as USB2(Bthub3)(z:) on my network. I still can't find it connected to the HH6. The drive is my main backup so I have to point several programs to it. Any help would be much appreciated. I am trying from a Windowes 7 laptop and a Windows 10 laptop.
Message 15 of 59
Update.
I have found the drive!
I connected it directly to my laptop and realised that it was named MUSIC. This name never appeared when it was connected to the HH3. I can now backup to it at \\192.168.1.254\MUSIC. Sorry for being so stupid....it's goes along with grey hair.
Message 16 of 59
Recognised Expert
Message 17 of 59
Quick update on this. So even though there's a workaround to find and map the drive, after a few days it stops responding.
New connections will be remembered.
Status       Local     Remote                    Network
             H:        \\192.168.1.249\Hitachi1TB   Microsoft Windows Network
OK           N:        \\nas\smf22                  Microsoft Windows Network
OK           V:        \\nas\vmstore                Microsoft Windows Network
Insufficient system resources exist to complete the requested service.
Delete and try to re-map the disk.
C:\Users\smf22>net use /d h:
h: was deleted successfully.
System error 8 has occurred.
Not enough storage is available to process this command.
To get it working again I needed to restart the hub. I should add this is running firmware version SG4B100021D0, which I realise isn't the current latest version, but I'm not connecting this thing to my Broadband to get it an update.
Regards
Newbie
Message 18 of 59
I have just received my BT Smart Hubready for my service to go live tomorrow, so I thought that I would familiarise myself with the settings and in particular a USB stick.
To my surpsise though, when I looked at the USB port in devices it returned \\api\Disque_partage
To add to that there is text that reads:
Lorem ipsum dolor sit amet, consectetur adipiscing elit.
Aenean euismod bibendum laoreet. Proin gravida dolor sit amet lacus accumsan et viverra justo commodo. Proin sodales pulvinar tempor.
**bleep** sociis natoque penatibus et magnis dis parturient montes, nascetur ridiculus mus. Nam fermentum, nulla luctus pharetra vulputate, felis tellus mollis orci, sed rhoncus sapien nunc eget odio.
None of what looks like latin can be recognised by Google translate, so wondered what is going on.
I can recognise that Disque_partage is French for shared disk but I am left wondering whether somebody at BT is having a laugh.
Recognised Expert
Message 19 of 59
Google for lorem ipsum. It's random text that was originally used in publishing and graphic design so as not to distract from images, layout etc. It's now used by web developers and programmers for similar purpose.
Regards
Recognised Expert
Message 20 of 59
And possibly someone at is BT is having a laugh as this should be removed before "the product" hits the street.
