Message 1 of 9
Smart Hub compatibility with mesh WiFi?
Hi guys
I'm thinking of either buying a router or one of these newer mesh set ups to fix the problem with WiFi drop outs.
I'm currently using the BT Smart Hub and wondered why everything I read suggests that it wouldn't work with Google WiFi (owing to lack of a bridge /modem only mode), but from what I've seen, 9t WOULD work with BT Whole Home.
Is that correct and if so why?
Many thanks
Z
8 REPLIES 8
Message 2 of 9
Re: Smart Hub compatibility with mesh WiFi?
You can use the smart hub with the BT Whole Home system.
https://www.shop.bt.com/learnmore/bt-branded-products-and-services/bt-whole-home-wi-fi/
It uses either Ethernet or wireless from the smart hub, for the backhaul connection.
Message 3 of 9
Thanks, but why doesn't the Smart Hub work with Google WiFi?
Message 4 of 9
Its not advisable to use it just as a wireless acces point.
See https://productforums.google.com/forum/#!msg/googlewifi/HoBfa6ssqQw/v3HKdyIyAgAJ
Message 5 of 9
Thanks.
But still doesn't explain what's different about BT Whole Hub that makes it possible to use with a Smart Hub and why Google WiFi can't...
Message 6 of 9
@zudecke wrote:
Thanks.
Totally different systems. Google Wifi is designed to be have an Internet address from a modem, or a router in bridge mode. (Internet address range)
Whole Home Wifi is designed to work with a local LAN IP address (private address range)
Message 7 of 9
Ah ok, thank you :).
And its good reliable?
Message 8 of 9
I suggest you read what people have said on this forum, before making any decision.
https://community.bt.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&fil...
If its just one or two areas of the house which have poor wifi, then a BT Hotspot 600 kit is a cheaper solution and works well.
Message 9 of 9
I’m considering my options as I have a smart hub with poor WiFi connectivity in one room in particular.
as it doesn’t seem like another manufacturer mesh solution will be compatible with the smart hub and I am tied to a contract until next year, I wonder whether BT whole home could be an option.
what did you do and would you recommend?
