Pete1960
Message 1 of 5
Smart Hub installation problem
Background: I've had Infinity for over a year - working really well.  I decided to upgrade my hub (model 4a I think) to a Smart Hub.  Tonight I tried to install it and failed to get the broadband connected.  BT Service Desk have ordered a replacement, but I'm not at all convinced the problem is with the hub.  Here's why ...
The existing cabling consists of a master socket and filter, a DSL cable from the filter to a "small white box installed by Infinity engineer" and a standard Ethernet cable from the small white box to the Home Hub.  It's worked fine since it was installed.
BUT ... the Smart Hub hasn't got a Broadband Ethernet port.  It can only be connected using a DSL cable.  As far as I can see, there is NO WAY to connect it via the small white box.  When I connected it directly to the filter, it provided broadband but at a tiny speed - so not serviceable.
I'm pretty sure the replacement Smart Hub 6 won't fix the problem.  The included documentation doesn't tell me how to connect and I can't find anything in the "help" material.
Any experts out there?  Or somebody who's solved this already?
Here's hoping
Pete
4 REPLIES 4
imjolly
Message 2 of 5
Re: Smart Hub installation problem
You cannot use the modem (white box) with the new hh6.
You take the cable which goes from filter to modem and disconnect from modem and connect to dslchecker socket in hub -  so connection is socket to filter to hh6. Plug and play
john46
Message 3 of 5
you now use the DSL lead to your phone socket you no longer need the Openreach modem (small white box )the smart hub has its own inbuilt fibre modem the connection instructions are shown at the bottom left of the booklet sent out with the hub if your socket looks like this jusjst connect the DSL lead to the top socket it does not need a filter if your socket looks like this then it does need a filter
gg30340
Message 4 of 5
pippincp
Sage
Message 5 of 5
I wonder how long before the OP goes back to the modem + HH4?
