adair1973
Message 1 of 3
Smart Hub
I have Infinity 1 with a Home Hub 5.  I have an offer to upgrade to Infinity 2 and was wondering if I would get the newer Smart Hub as part of the upgrade?
2 REPLIES 2
Liam_
Recognised Expert
Message 2 of 3
Re: Smart Hub
You may be able to negotiate one as part of the upgrade deal but have a look through the forum for 'Smart Hub, Hub6' and see the issues quite a lot of people are having with it.  Then decide if the 'upgrade' to a Hub 6 is worth the bother.  Infinity 2 will be fine with your existing Hub5.
Dippu
Expert
Message 3 of 3
Re: Smart Hub
If you decide on Smart Hub then don't send back your HH5 just in case!
