johnctemple
Message 1 of 20
Smart Hubs and Hub 5 not working not working
I have had a Home hub 4 for many years but got an 'up'grade to a smart hub. When connected, the Smart Hub worked for a minute, then the connection seemed to drop out as I kept getting 'Time Out' messages. I am on Infinity speed. I reported this, and BT sent another Smart Hub. The same problem persisted, and then with a Home Hub 5 which they sent in desperation. The time out messages persist. I have retained all these hubs. Any advice on how to get the Smart Hub not to Time Out? Thanks.
19 REPLIES 19
licquorice
Message 2 of 20
Re: Smart Hubs and Hub 5 not working not working
johnctemple
Message 3 of 20
No. Will that stop the time outs?
johnctemple
Message 4 of 20
I should have said my router is hard wired to my desktop computer. I am not referring to wi-fi issues-I havent got that far with it as it just didnt work. Will splitting the bands help if it is hard wired?
licquorice
Message 5 of 20
No, but the smart setup might.
imjolly
Message 6 of 20
the hub sounds like it is waiting for you to set up device hence why @licquorice suggestion to turn off smart setup
johnctemple
Message 7 of 20
Smart set up isnt turned on-I have checked it. Any other suggestions?
licquorice
Message 8 of 20
Go back to using the Hub4 and modem.
johnctemple
Message 9 of 20
The other message I get is  ''there is no internet connection'' and after a few seconds, maybe 10 or twenty, the connection resumes.
johnctemple
Message 10 of 20
Yes, I have done that for the last year or so, but cant help feeling I am doing something wrong or should be able to adjust things so that one of these 3 hubs I have, works. The smart hub is meant to give better wifi and my house covers a wide area so would give a better wifi in theory which is why I am trying to get it to work.
''A network change was detected'' is another error message.
