Toggie
Message 1 of 6
Smart TV sound out of sinc
 When we are watching our Samsung Smart TV on usual terrestrial freeview all is fine until the evening when sound and vision go out of sinc. The tv is connected by BT Broadband Extender Flex 1000 and ethernet cable and also by usual tv ariel cable. I have to disconnect the ethernet cable to fix the sound .. even although we are watching through the ariel. If we want to use our TV for streaming we have to connect ethernet cable again. Can be connected all day with no problem but it always seems to go out of sinc in the evening. Hope someone can shed light on our wee probem. Thanks
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: Smart TV sound out of sinc
Welcome to this user forum.
Are you using a BT YouView box, or just a smart TV?
Toggie
Message 3 of 6
Hi Keith, Just a smart tv
Keith_Beddoe
Message 4 of 6
I will move this to the correct board.
Someone here may be able to offer an explanation.
XRaySpeX
Recognised Expert
Message 5 of 6
If you are just watching terrestrial Freeview it's coming over the normal aerial & has nowt to do with BT BB or its router.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Toggie
Message 6 of 6
Thanks...That's what I thought... but it defo affects the sound when the ethernet cable is plugged into the back of the tv. The only other way to fix it is to change channels then go back to the one you were watching ( but after a couple of times this isnt an option)
