Message 1 of 3
Smart hub 2 WiFi connection options
Looking into the bthomehub.home browser app, under my network you can see various connection options not available in the app.
is there a way to override options such as
1) always use this address, so you can force an address to be kept
2) dual band so we can force connection to a particular band rather than have it determined
2 REPLIES 2
Message 2 of 3
Re: Smart hub 2 WiFi connection options
You can set address reservation in Advanced settings > My Network
You can't force a device to connect to a particular wifi band within the hub manager.
Message 3 of 3
But wouldn't it be good if we could
