Message 1 of 1
Smart hub 2 name change for Ethernet
Just had Smart hub 2 installed so I changed its SSID plus passwords to be the same as the old SH6.  That avoids me having to change details on 8 devices!  WiFi all changed ok but when I open PC's windows explorer it shows the Hub having the original name as supplied.
I connect to the Hub using wired ethernet and my switch seems to pass the original name to my Western Digital cloud drive that does not recognise that name.
How can I change the Hub name that is output on the wired ethernet ports?  The hub interface only allows the SSID to be changed it seems.
