Checked2013
Expert
Message 11 of 12
Re: Smart hub 6 line stats
As the OP is on Infinity 1 they won't be able to get any higher speed than they are already getting
Jaseb41
Message 12 of 12
This is the dsl Checker results, but I was saying was when I had the hub5 setup it showed my maximum upload speed of over 21mps where as the hub 6 only shows 9995 which is the capped speed for infinity 1 and maximum download speed of around 58mbps but the hub 6 only shows around 56mbps probably the difference in the chipsets but I believe they both are Broadcom I'm on a eci cabinet?
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
High Low High Low
VDSL Range A (Clean) 73.8 55 20 18.1 49 Available -- Yes Yes --
VDSL Range B (Impacted) 62 35 20 10 30 Available -- Yes Yes --
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 5 -- 3 to 7.5 Available -- -- -- --
WBC ADSL 2+ Annex M Up to 5 Up to 1 3 to 7.5 Available -- -- -- --
ADSL Max Up to 2.5 -- 1.5 to 3.5 Available -- -- -- --
WBC Fixed Rate 2 -- -- Available
