zobbo
Message 51 of 56
Re: Smart hub keeps restarting
Here are the stats. I managed to scrape another 3mb data rate by turning on G.998.4
System Log - DSL Log
This page shows the detailed DSL status.
DSL InformationDSL Firmware VersionDSL Driver VersionDSL Link StatusDSL UptimeDSL modulationANNEX ModeDSL Exchange (DSLAM)Current ProfileSystem Vendor IDSystem Vendor Model IDModem Vendor ID
1.0.4.1
FwVer:5.5.2.7_A_A60901 HwVer:T14.F7_0.2
up
0 days 0 hours 11 minute(s) 11 seconds
ITU G.993.5(G.Vectoring), G.998.4(G.INP, Downstream only)
ANNEX A
Broadcom
17a
2605443544e00
00000000000000000000000000000000
26005443434E5A01
Line StatsTCM(Trellis Coded Modulation)SNRLine AttenuationPath ModeInterleave DepthData RateMAX RatePOWERINPINP-SHINEINP-REINCRC
 DownstreamUpstream
On
On
3.2 dB
5.9 dB
14.8 dB
30.2 dB
FastPath
FastPath
1
1
66422 kbps
16599 kbps
83780 kbps
16599 kbps
14.4 dbm
7.2 dbm
1.0 symbols
39.0 symbols
0.0 symbols
0
0
zobbo
Message 52 of 56
Now the data rate has dropped to 55mb. Hmmm. Not good. To be honest the smart hub seems better. The Asus WiFi doesn't seem to be that stable either.
zobbo
Message 53 of 56
I've plugged my smart hub back in, but the data rate is still low at 53mb. Hopefully the DLM will bump that over time. But weird though since when I initially plugged it in it was up at 71mb straight away.
imjolly
Message 54 of 56
Can you post the hh6 stats for reference
zobbo
Message 55 of 56
Sure, here you go:
This is a list of your BT Smart Hub settings and current statistics.
Product name: BT Hub 6A
Serial number: +084319+NQ62764032
Firmware version: SG4B1000B522
Firmware updated: 26-Jan-2018
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 0 Days, 0 Hours 14 Minutes 41 Seconds
Data rate: 15.30 Mbps / 53.31 Mbps
Maximum data rate: 15297 / 63918
Noise margin: 6 dB / 6.2 dB
Line attenuation: 21.1 dB
Signal attenuation:
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 2 MB Uploaded / 6 MB Downloaded
Broadband username: bthomehub@btbroadband.com
BT Wi-fi: Active
2.4 GHz wireless network name: BTHub6-3W8P
2.4 GHz wireless channel: Smart (Channel 11)
5 GHz wireless network name: BTHub6-3W8P
5 GHz wireless channel: Smart (Channel 36)
Wireless security: WPA2 (Recommended)
Wireless mode: Mode 1
Firewall: On
MAC address: 40:C7:29:0A:96:95
Software variant: -
Boot loader:
imjolly
Message 56 of 56
big difference in attainable and connection speed
