imjolly
Message 21 of 56
Re: Smart hub keeps restarting
if you can hear noise on quiet line test then you need to report a phone fault NOT broadband to 151
zobbo
Message 22 of 56
I rang 151, they did a test, said there was no noise and booked an engineer for Friday. Should I tell the engineer about the hub restarting?
Cheers,
imjolly
Message 23 of 56
As phone fault just get engineer to fix the line noise and broadband should then improve
zobbo
Message 24 of 56
The engineer came today and did some tests. They all passed. So he suggested getting a replacement hub. So I guess it's either the hub or an intermittent line issue. I've swapped to a spare filter I found to see if that helps.
zobbo
Message 25 of 56
Router just reset again, so it's not the filter. Uptime was 2 days which is a record.
zobbo
Message 26 of 56
Got into BT support, they opened a complaint. But then told me I needed to split my WiFi channels. I explained my router was resetting when I'm not there, therefore no WiFi devices are connected but this didn't seem to sink in. So I've split the channels for now. Seriously considering buying my owns VDSL router now.
Keith_Beddoe
Message 27 of 56
It may save you a lot of hassle, and only cost about £30. It would prove what the fault is. If its not the line, it has to be the home hub.
pippincp
Sage
Message 28 of 56
@zobbo wrote:
Hi Guys,
I've now got a BT corded phone (BT Duo 210 v2). I plugged it in yesterday in the hope it would magically resolve my issues but unfortunately the router reset today anyway, after about 1 day of uptime (currently a record). So I did a quiet line test using the standard socket (plugged in directly, no broadband connected/filter). I also tried it on the test socket. I could hear white noise/hissing at a low level in the background during the entire call (i.e. as soon as the automated response started). I wasn't sure if that was just the phone amplification or whether it actually is the line. In any case there was no noticeable difference between the sockets. What do you think?
Cheers,
Zobbo
You MUST use a filter for the phone, it is there to filter out the digital broadband signal. It will sound similar to the sound you used to get from a fax machine.
The filter is there so that you can use the RJ11 lead to connect the broadband router but more importantly to stop the broadband signal interfering with your phone line.
Don't know why no-one informed you of that earlier.
zobbo
Message 29 of 56
Got a replacement smart hub today. I noticed it's a Type A whereas my original one is a type b. Also this one says the firmware was updated today, my last one was dated 2016. Anyway, I'll see if it can manage more than 2 days uptime. The data rate seems slightly higher aswell.
AndyCoffin
Message 30 of 56
Are you sure thats a smart hub? the mac address is registered to the Arcadyan Corporation where as all the hubs ive had have been from Sagemcom Broadband SAS.
The firmware version you have there looks more like a home hub 5b
I belive the smarthub B is ment for FTTP as well as it has one of the lan ports converted to a wan port instead or have i missed a new supplyier for the smarthubs?
I would recommend getting the bt wifi (bt fon) turned off as well if you dont use bt hotspots when out, on my hub it made things much more stable.
EDIT: sorry put wrong hub down
