Message 1 of 2
Smart hub slow link speeds compared to Hub 5
Hi
The downlink speed I can get using my Smart Hub has dropped to 7Mb/s.  If I plug my Hub 5 in I get 24Mb/s.
Has anyone else had this problem?  Any ideas on what could be causing it or is it likley the Smart Hub is faulty?
Fred
1 REPLY 1
Message 2 of 2
Re: Smart hub slow link speeds compared to Hub 5
if you are using wireless have you split the 2.4/5ghz networks and also selected a channel manually rather than leaving on auto
