Message 1 of 30
SmartHub 6a unable to connect to IP address
I just got my SmartHub today i cant access 192.168.1.254 from any browser on my PC but my phone i can access it any ideas?
29 REPLIES 29
Recognised Expert
Message 2 of 30
Re: SmartHub 6a unable to connect to IP address
Has the PC got an IP address? If you run ipconfig from the command line you should see the address. If it has an address can you ping the router?
Regards
Message 3 of 30
Try this link
Home Hub
Some browsers assume you are doing a search.
Message 4 of 30
PC does have a IP address also that link doesnt work.
Recognised Expert
Message 5 of 30
What IP address is your PC displaying?
Message 6 of 30
IP 192.168.1.10
SubNe t255.255.255.0
Gatway 192.168.1.254
DNS 192.168.1.254
I have tried it with a dynamic address it looks like the hubs refusing incoming connections from my pc.
Recognised Expert
Message 7 of 30
Did you try a ping e.g., ping 192.168.1.254? Also is the PC using DHCP to get an address? The default range is .63 and higher.
Recognised Expert
Message 8 of 30
Odd, settings are fine. Can you try, from command prompt, ipconfig /release
Then ipconfig /renew
If that don't work try resetting the Hub.
Message 9 of 30
Also responds at bthub.home
Message 10 of 30
Already tried that with no joy and the factory reset also bthub.home dont work.
