Recognised Expert
Message 11 of 30
Re: SmartHub 6a unable to connect to IP address
Not something simple like Java disabled in the browser perhaps?
Seeing as the phone connects.
Message 12 of 30
Tried connecting with Microsoft Edge and Google Chrome latest version all uptodate even disabled Kaspersky.
Recognised Expert
Message 13 of 30
Can you disable IPv6 and try again. Assuming it's enabled that is, on by default in Win 10.
Message 14 of 30
Just tried that no joy.
Just got hold of BT on the phone, been told i have to pay for support for the smart hub when its BT hardware.
Recognised Expert
Message 15 of 30
Very helpful. Glad I never use hubs. I think you've covered all the bases so unless someone can think of something else may be best to go back to the old router and try for a refund on the new hub.
Message 16 of 30
Hoping someone from BT picks this up as ive exhahsted everything i can think of.
Recognised Expert
Message 17 of 30
Using the phone, if you connect to the hub and go to Advanced settings -> My network -> Devices, do you see the PC? If so are the MAC and IP address correct?
Message 18 of 30
MAC Address and IP address  are correct, if i remember correctly i had an issue like this with the Hub5 Type B.
Message 19 of 30
Have you tried a factory reset of the home hub?
Message 20 of 30
Three times now i can even access it from my TV but not my PC.
