Ynoppony
Message 1 of 1
SmartHub6 and Sony android TV (wired connection)
Hello,
I'm going insane trying to make my Sony Bravia Android TV stay connected through ethernet cable.
Every now and then it just says it can't connect to the internet, sometimes it says it doesn't even see a cable (I've already tried to change the cable, same problem).
It was giving me a very weird ip address for the tv, so I tried assigning a static one, but it still decides it doesn't want to work. If I try to restart the router (after ages in which the broadband just doesn't work) it works for a while and then it just stops working again.
I also tried hard resetting the hub and formatting the tv, but no luck. Smart setup is already disabled.
Thanks.
