nesswill
Message 1 of 19
SmartTalk problem
Hi i get this error on both hand sets?
I have looked at all the know issues and none of them apply - help please?
...if the world didn't suck we'd all fall off...
18 REPLIES 18
Message 2 of 19
Re: SmartTalk problem
Try the helpdesk on  0800 011 3845
I assume that you are the account holder and you have checked on MyBT to see if its set up correctly to allow new registrations?
nesswill
Message 3 of 19
hi apatr from the download page there is nothing else anywhere to access?
Message 4 of 19
If you log into MyBT using a computer, there should be a page to manage your Smartphone settings. See these images.
This takes you to the next page to manage your service.
nesswill
Message 5 of 19
hi no i dont get that, just the set-up page?
thanks
Message 6 of 19
thanks
It needs to be initially setup from the account holders MyBT web page, so you will have to use a computer first, and login to your account. This is for security, so that nobody can add a phone without the account holder`s permission.
Use this link https://www.bt.com/appsauth/genericlogin.do?TARGET=/appsyouraccount/secure/index.do?siteArea=con.mya
nesswill
Message 7 of 19
thank you but i can not see anywhere to do that??
Message 8 of 19
Log into MyBT.
Select your home phone account from the list of accounts. It shows your bill on that page also.
Look at the bottom of the screen for "My Extras"
nesswill
Message 9 of 19
hi i can see that but it just says 'setup smarttalk' and when you go in there all you can do is download the app (i have done and installed) no option to set anything up??
thanks
ness.
ps can not access your pages as i am at work on not on a bt line.
Message 10 of 19
Are you using a normal PC to access MyBT, can you see all the other extras like BT Cloud etc?
I assume you can see your phone bill?
